death wobble and other - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mock12v, this thread has received 6 replies and been viewed 3425 times.
post #1 of 7 (permalink) Old 11-29-2010, 06:47 PM Thread Starter
riding in the dirty dozen
ok long story short...i snapped a tie rod end..i replaced all tie rod ends. drove it to work after getting it aligned and it death wobbled on me twice. so i replaced the steering stabalizers and the passenger side one was deff blown. and it hasnt wobbled on me since despite trying to make it happen. buutt the front end still seems to want to do what ever it wants to. it either pulls hard to the left or hard to the right and its never happend before snaping the tie rod. if im turning i have to physically put it straight or it will just stay there(like its not wanting to straighten itself out) i could do circles all day long if i wanted to. i just need some advice because its killing me.. its an 06 ram 2500. so new tie rod ends new bilstein shocks and new stabalizers since the snapped tie rod and death wobble
1998 Dodge cummins 12v, #10 plate and afc FF, BHAF, Isspro guges, homemade boost elbow,tabbed kdp
coming soon stacks,tires:Thumbup:
mock12v is offline
post #2 of 7 (permalink) Old 11-29-2010, 07:42 PM
TDG Mafia - Booze Runner
Snowaholic's Avatar
What tires are you running? Could be Ball joints too..
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline
post #3 of 7 (permalink) Old 12-02-2010, 04:15 PM
Diesel Duo's Avatar
Check Track Bar also.
I love my Thuren unit. Very stout.
No brand loyalty, just a love of diesels!!
1994 Ram 2500 CTD K&N intake, MBRP exhaust, full Goerend tranny, #100 Fuel plate, 60# valve springs, 4k GSK, Thuren steering stabilizer, Thuren Track Bar, +2.5" progressive rate coil springs, Bilstein 5100's, BD Diesel SBS, chassis mods, 315/75R16 Goodyear Wrangler Duratrac, Isspro tri-pod EGT, fuel, and boost, Eclipse CD, 8' Boss snowplow
Fuel Heater Deleted! KORE dual Heim Joint end links waiting to go in
2004 F-250 Powerstroke aFe stage II, Hypertech PTM, Recon mirror markers, Firestone airbags w/ compressor, Rancho 9000's on all four w/ myride, 20" Pacer on 33/12.5 Nitto Mud Grapplers, Eclipse CD, 8' Boss snowplow
Blizzard IceChaser 1.5 cubic yd. poly salt and sand spreader!
Diesel Duo is offline
post #4 of 7 (permalink) Old 12-03-2010, 12:18 AM Thread Starter
track bar? you mean sway bar or is there another bar i aint seeing. and im running nitto dune grapplers 37's on 20's. none of this has happend since snapping that tie rod. i even have dropped 2mpg. i figured it would go up or stay the same with new parts!!! i was apparently wrong. i swear if someone was to burn it to the ground id be happy
mock12v is offline
post #5 of 7 (permalink) Old 12-03-2010, 07:46 PM
Snowaholic's Avatar
Yes there is a Track bar. Thuren is an exelent replacement, I changed to a Carli Adjustable from the OEM.
How did you snap the Tie rod? Did it cause an impact on one of your tires? Are the Grapplers D rated, I don't know...
post #6 of 7 (permalink) Old 01-24-2011, 01:49 AM
HUMMINCUMMINS's Avatar
are your front tires wearing way different wear pattern? and does your front end feel like it has a shudder to it?
HUMMINCUMMINS is offline
post #7 of 7 (permalink) Old 02-13-2011, 03:29 PM
bmoeller's Avatar
Is the tie rod adjusted correctly? Sounds like not enough toe in, and it is hunting all over in the truck grooves in the road.
"Obama = Hoax and Chains"
bmoeller is offline
Death wobble? CODE3RSQ 2003-2007 6.0L Power Stroke 4 12-24-2008 03:58 PM
Death Wobble? NukleusX 5.9L Cummins 12 Valve (1994-1998.5) 21 03-05-2008 05:30 AM
Death wobble 2wd? imported_diesel_ General Ford Truck and Excursion 8 08-11-2007 03:02 AM
death wobble??? alldiesels General Ford Truck and Excursion 3 06-06-2007 12:25 PM
Another Death Wobble Fix... DSI General Ford Truck and Excursion 6 04-20-2007 09:45 AM
