'04 3500 with death wobble, 3 shops say front end is fine - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hayjayhorses, this thread has received 4 replies and been viewed 3840 times.
post #1 of 5 (permalink) Old 01-06-2011, 02:48 PM Thread Starter
hayjayhorses's Avatar
My friend has an '04 that is doing the death wobble when he hits a bump the right way. I the past month he replaced every tie rod end, rebalanced the front tires, had the front end aligned, installed a new stabilizer, to try to remedy the death wobble.
He brought it to 3 front end shops plus to dealers they all tell him the front end is fine. Are the spec limitations for this truck's front end sloppy to begin with.
I put the truck on a drive on lift and could not get any play out of the track bar.
any suggestions?
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #2 of 5 (permalink) Old 01-23-2011, 10:16 PM
learnin' as I go...
killsme's Avatar
I could not get any play out of mine manually when in the air. I had my wife saw the wheel back and forth when the truck was on the ground, while I laid on the driveway and watched the underside. Thats when I saw things sliding left to right. An upgrade to the Thurenfab track bar tightened things up nicely. No more death wobble.
'13 Ram 2500 4x4 club cab
killsme is offline
post #3 of 5 (permalink) Old 01-28-2011, 09:38 PM
Diesel Duo's Avatar
Agreed. I love my thuren unit also. Very stout. Pricey but worth every penny; for confidence while towing! Also safty I experienced the "death wobble" and it is not fun.
No brand loyalty, just a love of diesels!!
1994 Ram 2500 CTD K&N intake, MBRP exhaust, full Goerend tranny, #100 Fuel plate, 60# valve springs, 4k GSK, Thuren steering stabilizer, Thuren Track Bar, +2.5" progressive rate coil springs, Bilstein 5100's, BD Diesel SBS, chassis mods, 315/75R16 Goodyear Wrangler Duratrac, Isspro tri-pod EGT, fuel, and boost, Eclipse CD, 8' Boss snowplow
Fuel Heater Deleted! KORE dual Heim Joint end links waiting to go in
2004 F-250 Powerstroke aFe stage II, Hypertech PTM, Recon mirror markers, Firestone airbags w/ compressor, Rancho 9000's on all four w/ myride, 20" Pacer on 33/12.5 Nitto Mud Grapplers, Eclipse CD, 8' Boss snowplow
Blizzard IceChaser 1.5 cubic yd. poly salt and sand spreader!
Diesel Duo is offline
post #4 of 5 (permalink) Old 02-13-2011, 03:04 PM
bmoeller's Avatar
Put in poly bushings in the trackbar will help, if the OEM ones are rubber.
http://sourceautomotive.biz/2003-200...nglinkage.aspx
This is a must have item. Night and day difference in my '97 and '99 (as was the 3rd gen trackbar upgrade)-
http://sourceautomotive.biz/2003-200...ilizer4x4.aspx
Running 2 steering stabilizers helps too.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 5 (permalink) Old 02-13-2011, 03:26 PM
bmoeller's Avatar
The ball joints are a common problem on the AAM axles as well. Some junk within 30k miles.
bmoeller is offline
death wobble and other mock12v Dodge Suspension 6 02-13-2011 03:29 PM
Death Wobble Help JSL1990 5.9L Cummins 12 Valve (1994-1998.5) 3 05-24-2010 05:02 PM
Death Wobble? NukleusX 5.9L Cummins 12 Valve (1994-1998.5) 21 03-05-2008 05:30 AM
death wobble??? alldiesels General Ford Truck and Excursion 3 06-06-2007 12:25 PM
Another Death Wobble Fix... DSI General Ford Truck and Excursion 6 04-20-2007 09:45 AM
