96 3500 front suspension - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by drkllr, this thread has received 7 replies and been viewed 3156 times.
post #1 of 8 (permalink) Old 12-28-2012, 02:00 AM Thread Starter
drkllr's Avatar
My Front end is developing some play. got a new box and stabilizer. My tie rod ends pitman rod ends and track bar are showing some age. what suppliers have good replacement parts or is factory the best option.
97 3500 kdp fixed, 3gsk, 16.5 timing 10 plate full forward , 4" exhaust goerend full build transmision. industrial injection 90 hp injectors, banks twin ram intake, dpi exhaust, bd superb 57/65 hx 40 downpipe, bhaf
97 international 4700 444e/7.3 one tuner nothing else yet
96 3500 dodge haisley head port and polish street cam 5x13 inj speraco intercooler bd r 700 towing twins mbrp exhaust
drkllr is offline
post #2 of 8 (permalink) Old 12-28-2012, 02:29 AM
Aimless Wanderer
Either Moog, Mcquay-Norris, or A-1 Cardone all make good aftermarket parts. The thing to make them last is grease. Some of the front end parts on the Dodges could not be greased or relubricated. The replacement ball joints will have a way to relubricate them by removing the grease zerk, and installing a plug in it's place to allow the front driveshafts to turn. Some joints have side mounted zerks and you don't need to remove them. My 96 Dodge 3500 has near 300K on it and the tie rod ends, and pitman arm are original to the truck. The original ball joints were shot at 70K as was the idler arm. These parts did not have zerks from the factory and their replacements do.
Backslap is offline
The Following User Says Thank You to Backslap For this addition to TDG:
drkllr (12-28-2012)
post #3 of 8 (permalink) Old 03-09-2013, 01:12 AM
2 or 4 wheel drive?
later is offline
post #4 of 8 (permalink) Old 03-09-2013, 01:45 AM Thread Starter
drkllr's Avatar
4x4 on both trucks
drkllr is offline
post #5 of 8 (permalink) Old 03-09-2013, 11:34 AM
Aimless Wanderer
Originally Posted by later View Post
2 or 4 wheel drive?
Track bars are used on the front drive axle to keep it from moving from side to side under the truck.
Backslap is offline
post #6 of 8 (permalink) Old 03-09-2013, 01:55 PM
BUCK2's Avatar
Here is what I did with really good results. I bought a front end rebuild kit from performance suspension technologies. Comes with all polyurethane bushings for control arms new tie rod ends and a new tie rod bar and ball joints (IMOP are junk). I threw the ball joints away and bought OE, intalled all other parts and a new track bar form Napa. Then I bought a aftermarket steering brace it is bolted in place with your sway bar bushings and then to the steering gear box. Did and alignment and the truck drove awesome. The steering slop was gone and the death wobble was gone. It has been that way for 30K miles. This is on my 95 model.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #7 of 8 (permalink) Old 03-09-2013, 11:35 PM Thread Starter
drkllr's Avatar
Thanks guys ill look em up
drkllr is offline
post #8 of 8 (permalink) Old 03-10-2013, 03:44 AM
Right, I have heard many thing call something different and just wanted to be sure.
later is offline
front air suspension Quantum 2008-2010 Body & Suspension 6 02-05-2010 09:54 PM
Squeak in front suspension Alpha6 2008-2010 Body & Suspension 2 05-17-2009 07:43 PM
where can i get an airbag suspension kit for and 07 3500 dodge? yfz450_0569 General Dodge Discussion 4 03-21-2008 08:29 PM
Front suspension... Zaairman 1994-2003 7.3L Power Stroke 7 02-07-2008 06:35 AM
GMT 900 platform front suspension? Rutcutter Duramax 07.5-2010 (LMM) 37 10-09-2006 11:41 PM
