best way to lower the rear? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Sabbath5.9, this thread has received 6 replies and been viewed 1404 times.
post #1 of 7 (permalink) Old 09-05-2009, 02:26 AM Thread Starter
Upside Swordfish
Sabbath5.9's Avatar
whats the best way to lower the rear of my truck? so its level with the front
Jeff
1996 ram 2500 ex cab long 2wd, 5'' straight, 215s, 4k gsk(only revin till 3k), 16* timing, fuel plate MIA, afc modded FF, CFM intake mani, afe stage 2
15.40 at 90.61 in the 1/4th (09-18-10)
Sabbath5.9 is offline
post #2 of 7 (permalink) Old 09-06-2009, 01:57 PM
Is it a 4X4 or 2wd?
later is offline
post #3 of 7 (permalink) Old 09-07-2009, 10:05 PM
SSpeeDEMONSS's Avatar
shackles.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #4 of 7 (permalink) Old 09-08-2009, 04:04 AM
81 Isuzu /C223na, 5spd
keydl is offline
post #5 of 7 (permalink) Old 09-09-2009, 03:56 AM
Trip's Avatar
unless its 4wd then raise the front,
WALNUT (anti-ACORN) member#23
Trip is offline
post #6 of 7 (permalink) Old 09-09-2009, 03:26 PM
PhilipR's Avatar
I have seen guys cut the stock spacer blocks down and put on new U-Bolts with good results.
-Phil-
PhilipR is offline
post #7 of 7 (permalink) Old 09-13-2009, 04:05 AM
Skyd Ram's Avatar
Yup,
Have the blocks milled down a little and redrill the centering pin hole.
George
2010 CCSB Laramie Ram 2500 4x4
Powered By:
H&S/Shibby/Black Ops/Flo Pro
Suspended by:
Carli Suspension/Bilstein
2008 RCLB F250 XLT 6.4 Auto
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Pure Performance/Carli/Bilstein
Skyd Ram is offline
Downpipe for the lower 48 sledneck57 2008-2010 6.4L Engine Tuner Forum 30 07-08-2009 11:40 PM
lower valance Superstroker General Ford Truck and Excursion 1 01-30-2009 04:56 AM
lower EGT's Onebadtruck 24 Valve Performance 11 04-24-2008 10:16 PM
Lower Egt's? Rigwelder25 2003-2007 6.0L Power Stroke 27 03-09-2008 04:13 AM
Lower it or leave it? Mr Mooring Products General Ford Truck and Excursion 2 05-02-2007 03:43 PM
