i guess this really aint under suspension topic - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 5 replies and been viewed 1622 times.
post #1 of 6 (permalink) Old 10-26-2009, 03:32 PM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
but i got a 97 cummins and theres alot of play in the steerin wheel i was thinkin its my gearbox out of round but i really hope not but theres roughly a 1/16 or a lil more play in the wheel before it turns in general but any ideas are appricated
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 6 (permalink) Old 11-01-2009, 02:00 AM
There is a sector lash adjustment opposite the sector shaft/pitman arm nut. Loosen the locknut and gently take up the slack with the steering box centered ( high point ). If you can feel the high point it is to tight. I use just an extension with NO drive handle.
To tight will make it a ditchfinder, but then it may already be one.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 6 (permalink) Old 11-01-2009, 11:58 PM Thread Starter
alright ill try it and see what happens but the gear box is leakin so im trien to find where its at all
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #4 of 6 (permalink) Old 01-15-2010, 12:01 AM
TDG Mafia Member
Cumminspower59's Avatar
http://www.sourceautomotive.biz/shop...4x4-50-20.html
This should help your steering as well.
You stay classy Diesel Garage
Cumminspower59 is offline
post #5 of 6 (permalink) Old 01-15-2010, 09:26 PM
There is an adjusting screw on top of the gear. Back off the jam nut, use an allen key to tighten the screw. Do a little at a time then drive it until you get the desirable feel.
The solid steel brace works good, and the pillow block bearing takes alot of the stress off the sector shaft...
Fast_Ashley is offline
post #6 of 6 (permalink) Old 01-19-2010, 02:47 AM Thread Starter
ok thanks!!
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
Aint there any Nor Cal peeps? nevrenufhp Southwest 74 11-11-2010 10:01 PM
I aint ever!!!! dragnsled The Parking Lot 12 01-15-2009 01:46 PM
Need Help, something aint right BWdiver 5.9L Cummins (2003-2007.5) 10 03-20-2008 04:06 AM
I aint touchin it DarkSyde The Parking Lot 3 11-22-2006 05:16 PM
Just Aint Right! Choke_On_My_Smoke Road Kill, Bench Racing 20 08-27-2005 06:11 AM
