Clunk/Pop sound - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PhilipR, this thread has received 5 replies and been viewed 2069 times.
post #1 of 6 (permalink) Old 02-16-2010, 02:35 PM Thread Starter
PhilipR's Avatar
Clunk/Pop sound
I have a random clunk/pop kind of sound coming from the truck when i get on the brakes to slow down. It doesn't happen as soon as I touch the pedal but when I start slowing down. All my tie rods are good, track bar is good, ball joints have a little play and that was my first suspect but I was reading about a bushing in the steering column that can go bad and it causes a clunking sound and I was wondering it that could be the culprit. I just turned over 250K miles.....Anyone happen to have this issue before? Also is there anyone besides Top Gun that sells new tubular control arms for my '98? I'd like to just swap them out when I do the ball joints.
-Phil-
PhilipR is offline
post #2 of 6 (permalink) Old 02-18-2010, 01:18 AM
gone fishin!
thuren makes some bad azz control arms and other suspension components... might want to go over your front brakes with a fine tooth comb, i had a vibration in the front end that wouldnt go away and turnd out that the front drivers side caliper was cracked and broken, moving around warped the crap out of the rotor, it started as a snaping sound that turned into a vibration.
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #3 of 6 (permalink) Old 02-18-2010, 12:58 PM Thread Starter
PhilipR's Avatar
I'll check out Thuren Fab....thanks.
I pulled the calipers off cause I though it sounded like pads sliding.....I'll do it again and go over it a bit closer and check for cracks in the caliper.
-Phil-
PhilipR is offline
post #4 of 6 (permalink) Old 02-24-2010, 04:31 AM
Skyd Ram's Avatar
It could definitely be the control arm bushings. Carli makes an awesome set of control arms for the second gen Dodges. The noisy steering column usually happens when turning the wheel at lower speeds.
2010 CCSB Laramie Ram 2500 4x4
Powered By:
H&S/Shibby/Black Ops/Flo Pro
Suspended by:
Carli Suspension/Bilstein
2008 RCLB F250 XLT 6.4 Auto
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Pure Performance/Carli/Bilstein
Skyd Ram is offline
post #5 of 6 (permalink) Old 02-24-2010, 01:08 PM Thread Starter
PhilipR's Avatar
Thanks Skyd Ram. I have new ball joints onm the work bench and I am going to put them in since I have 250K on the stock ones and they have a little play.....not much which is AMAZING with the mileage.
-Phil-
PhilipR is offline
post #6 of 6 (permalink) Old 03-23-2010, 12:56 PM Thread Starter
PhilipR's Avatar
Well I finally got the time to get new ball joints installed and that fixed the sound. It's SO much nicer to drive this truck with the new ball joints and front end aligned.
-Phil-
PhilipR is offline
Popping sound / gurgling sound from IP Black06 2008-2010 6.4L Power Stroke 28 10-25-2009 08:29 PM
Clunk! gratefuldawg 2003-2007 6.0L Power Stroke 0 05-07-2008 01:55 AM
clunk!! 99stroke 1994-2003 7.3L Power Stroke 12 04-11-2008 03:08 AM
Front End Clunk Again Strokin05 General Ford Truck and Excursion 1 05-18-2007 04:17 AM
Clunk sound when in reverse imported_thnkfst 2003-2007 6.0L Power Stroke 2 04-08-2007 02:20 PM
