More on the 2011 IFS and other changes.. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 747MD11, this thread has received 53 replies and been viewed 9099 times.
post #1 of 54 (permalink) Old 12-22-2010, 06:38 AM Thread Starter
Duramax/Allison
747MD11's Avatar
There seems to be quite a bit of confusion I've found by many members as to just how different the 2011 is from the 2010 and prior model HD's.. There's a lot of stuff, too much to cut n' paste into a thread
For more, just click HERE . Like I said, there are a lot of technical differences, but two major changes that stick out:
The new IFS:
2. New and strong independent front suspension
A completely redesigned independent front suspension system offers up to a 25-percent greater front axle weight rating – up to 6,000 pounds (2,721 kg) front gross axle weight rating (FGAWR) – enabling a snow plow to be used on all 4WD cab configurations with the available snow plow prep package, while also supporting improved ride and handling characteristics.
Silverado’s signature short-long arm/torsion bar front suspension design is retained, but now features new, forged steel upper control arms that are stronger and lighter than their predecessors. The new lower control arms are made of precision-machined cast iron to handle the greater loads. Five different torsion bar rates support five different front gross axle weight ratings (a single torsion bar was previously used for all models). This helps stabilize the range of trim heights of various models under load, while enhancing appearance, handling, durability, tire wear and alignment. The trim height is adjusted on each bar via a single bolt, easily allowing the height to be changed to account for the weight of a snow plow or other accessories.
The Silverado HD front suspension now uses a pair of urethane jounce bumpers on each side, instead of one, for improved load management; and there’s a new upper shock mount attachment design that’s positively connected to the frame with two fasteners. This design eliminates squeaks and clunks, while supporting higher load capability and increased durability.
Compared to competitors’ beam-axle front suspension, the Silverado’s independent front suspension provides a better ride, more accurate trim height control (with fewer parts) and greater flexibility to adjust the alignment for weight and tire sensitivity.
the new frame:
1. New frames
In the quest to comprehensively redesign the Silverado HD chassis to improve durability and ride, while also supporting increased capability, engineers developed 11 all-new, fully boxed frame assemblies. The frames have increased cross sections and use more high-strength steel for greater durability, higher towing capacity and improved ride and handling; the front sections are hydroformed.
The bending and beaming stiffness of the frames is increased 92 percent and 20 percent, respectively, with the fully boxed sections enhancing torsional stiffness by a factor of five. Also, larger engine and transmission mounts, coupled with a 125-percent-stiffer front frame structure, provide greater vibration control, while hydraulic body mounts are incorporated under the cab section on extended and crew cab models for a more isolated feel inside.
Engineers addressed common customer and aftermarket uses when designing the new frames, including adding access holes to the rear frame section to enable easier installation of fifth-wheel/gooseneck-style hitches. Also, the frame-mounted hitch for conventional trailering is stronger, with a box-tube design. It supports up to 16,000 pounds (7,257 kg).
2011 Duramax 2500HD LTZ
100% US Made of mostly US parts with some parts from Germany and Japan.
Video of my truck: Youtube Video
2005 E320 CDI
2008 BMW X5 4.8i
747MD11 is offline
The Following 3 Users Say Thank You to 747MD11 For this addition to TDG:
Duke (12-23-2010), french277 (12-25-2010), todt061458 (01-22-2011)
post #2 of 54 (permalink) Old 12-22-2010, 07:55 AM
I need to upgrade
SOCAL DIESEL TRUCKS .COM
CHORIZOSDMAX is offline
post #3 of 54 (permalink) Old 12-23-2010, 03:05 AM
'Ol Builder guy
Duke's Avatar
yeah, the new truck is definately making me re-think keeping my '07 and buying another '06-'07.
The scary thing is I LOVE my '07. I really can't see how it get much better! lol
Duke is offline
post #4 of 54 (permalink) Old 12-24-2010, 05:15 AM Thread Starter
Duramax/Allison
747MD11's Avatar
HERE are some pictures of an LML with full snowplow package... looks great, and the report is that it runs great too.
2005 E320 CDI
2008 BMW X5 4.8i
747MD11 is offline
The Following User Says Thank You to 747MD11 For this addition to TDG:
Duke (12-24-2010)
post #5 of 54 (permalink) Old 12-24-2010, 06:54 AM
cant see pics need to be a member
post #6 of 54 (permalink) Old 12-24-2010, 06:58 AM Thread Starter
Duramax/Allison
747MD11's Avatar
ok, here's two of em... the two best ones.
Name:	Updated Pics 217.jpg
ID:	27746   Click image for larger version
Name:	Updated Pics 227.jpg
2005 E320 CDI
2008 BMW X5 4.8i
747MD11 is offline
The Following 2 Users Say Thank You to 747MD11 For this addition to TDG:
CHORIZOSDMAX (12-24-2010), french277 (12-25-2010)
post #7 of 54 (permalink) Old 12-26-2010, 05:26 AM Thread Starter
Duramax/Allison
747MD11's Avatar
in keeping this thread updated with info on the 2011 2500/3500 differences.. here's a good video I came across on youtube.
2005 E320 CDI
2008 BMW X5 4.8i
747MD11 is offline
Duke (12-26-2010)
post #8 of 54 (permalink) Old 12-26-2010, 02:43 PM
'Ol Builder guy
Duke's Avatar
Very cool. My current thinking of owning my truck and another used one is starting to fade in favor of buying a new one......
Duke is offline
post #9 of 54 (permalink) Old 12-26-2010, 02:52 PM
Administrator
fordt's Avatar
Images: 5
I have been anxious to look a new one over, but to date I have not been able to find any on the lots I come across.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #10 of 54 (permalink) Old 12-26-2010, 03:51 PM Thread Starter
Duramax/Allison
747MD11's Avatar
you know, their definitely keeping inventories tight on the diesels ... Especially top of the line 4x4/LTZ types.. I had to look between 4 dealers to find a total of 4 trucks available, of which only one met my needs/wants.... this is helping keeping prices up too. They really wouldn't deal too much on these..... gone are the days of $7-10K off sticker (factory).... 2.5K was the result of a 6 hour negotiation!
2005 E320 CDI
2008 BMW X5 4.8i
747MD11 is offline
New 2011 CC/DRW OILBURNER6.6 Duramax 2011+ (LML) 42 12-30-2010 11:53 PM
2011 F-550 ROCCO 2011+ 6.7L Power Stroke Diesel 8 12-30-2010 07:13 AM
My New 2011 11Strokin 2011+ 6.7L Power Stroke Diesel 31 10-04-2010 04:07 PM
2011 BROKER 2011+ 6.7L Power Stroke Diesel 6 01-18-2010 04:25 PM
First Look: 6.7L 2011 F2/350 ! bushpilot 2011+ 6.7L Power Stroke Diesel 110 10-01-2009 07:48 AM
