fuel filter change - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by buffalobob, this thread has received 6 replies and been viewed 5972 times.
post #1 of 7 (permalink) Old 07-02-2011, 11:29 AM Thread Starter
buffalobob's Avatar
fuel filter change
its not time to change it yet, but i have encountered a delimna. instructions in owners manual state to lower the rear of the wheel well liner. may have been simple procedure before but with mud guards installed it will be a major undertaking. where else can the fuel filter be accessed without dismantling the truck.
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
post #2 of 7 (permalink) Old 07-03-2011, 05:54 AM
Pardue the Traveler
New 0mega's Avatar
It can be taken out from the top, its a bit of a pain or you can cut a door into the wheelwell liner.
Singles Club member #250
New 0mega is offline
post #3 of 7 (permalink) Old 07-03-2011, 11:23 AM Thread Starter
buffalobob's Avatar
i had thought about the door thing. didnt know if it would be a workable idea or not. thanks for the input. will give that a try. plan on having this truck a long time and want service to be user friendly
post #4 of 7 (permalink) Old 07-05-2011, 05:07 PM
I do my fuel filter when I rotate the tires that way it is easy to get access with a body tool to get the clips out and a driver drill to get the mud flap out. You only have to remove part of the inner liner to get access.
Johnp3 is offline
post #5 of 7 (permalink) Old 07-08-2011, 09:50 AM
Pardue the Traveler
New 0mega's Avatar
If you take your truck to a shop they'll just change it from the top instead of screwing with undoing the fender liner and taking off the mud flap to change the filter or a few of the guys do the door thing.
The Following 2 Users Say Thank You to New 0mega For this addition to TDG:
buffalobob (07-08-2011), french277 (07-14-2011)
post #6 of 7 (permalink) Old 07-12-2011, 06:52 PM
duramaxxx
walk in vs garage price
Anybody out here work at Napa or O'Reilly? I also am in need of filter change and was curious how much I can save using a garage discount for air/lube/fuel filters vs. walk in price...I don't really want to wait but will try to get buddy to help if savings are substantial.
Thx
RR
ravishingrick is offline
post #7 of 7 (permalink) Old 07-12-2011, 08:47 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
you could try www.dieselfiltersonline.com
Racor/AC delco is the filter is the one I would use from there, its the best quality, it may be a little more expensive, but it is worth it
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
change fuel filter cnacowboy 7.3L and 6.9 IDI (Pre 1994) 3 10-19-2010 06:36 PM
Fuel Filter change smokey03 2003-2007 6.0L Power Stroke 23 04-24-2010 03:47 PM
Fuel filter change Weed51 6.7L Cummins (2007.5-2011) 1 11-25-2007 07:26 PM
first oil change and fuel filter change? chvylac 2003-2007 6.0L Power Stroke 10 12-03-2006 09:26 AM
Fuel Filter Change hotrodstan Duramax 2004.5-2005(LLY) 6 02-26-2006 09:19 AM
