DPF and Fluid - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by barbershop, this thread has received 1 replies and been viewed 2023 times.
post #1 of 2 (permalink) Old 09-12-2013, 09:00 PM Thread Starter
idunnoyet
barbershop's Avatar
DPF and Fluid
I am looking at buying a 2011 GMC 2500 with the Duramax. I owned a 2003 at one time so I know about owning a diesel. What I don't know is the new emissions regs. How much does the emission control hurt the vehicle performace?
But Main question is how much DEF Fluid does these truck use? Is it Rate in MPG, and how much cost does this add to the ownership of the truck. Also I didn't see a gauge in the truck, just a light, how much warning does this light give you? Thanks
2012 Z-71 Duramax
1987 379 Peterbilt 425 Cat, RTX 15715, 390 rear ends.
1994 379 Peterbilt 425 Cat, 9 speed, 3:70 rears
Also drive anything that is overloaded and fast!!
CAN YOU KEEP UP!?!?!?!?
barbershop is offline
post #2 of 2 (permalink) Old 09-13-2013, 05:44 PM
Pardue the Traveler
New 0mega's Avatar
Well it depends on what you mean performance, if your talking stock then it doesn't hurt performance. now if your talking about adding power mods, then there is less choice then there has been. DEF usage depends on how you drive, but I've heard you only need to fill up twice a year maybe 3 times. as for cost its like buying an extra jug of washer fluid
Singles Club member #250
New 0mega is offline
The Following User Says Thank You to New 0mega For this addition to TDG:
barbershop (08-17-2014)
Fluid help please? ehopp88ss 5.9L Cummins (2003-2007.5) 1 10-16-2010 03:12 AM
Generic question about Urea/DPF vs DPF only rsv4me General Diesel 6 12-09-2009 10:34 PM
5" FLO-PRO DPF back exhast and DPF delete pipe. SEABEE08FX4 Whats Been Sold 4 12-06-2009 03:28 PM
Fluid changes? badford93 2008-2010 6.4L Power Stroke 10 10-06-2009 11:18 PM
Ok post Vids or DPF & DPF/DOC Deletes and STACKS Vids on 6.4L onebadf150 2008-2010 6.4L Engine Tuner Forum 40 04-26-2008 01:17 AM
