Diesel Truck Forum - TheDieselGarage.com - View Single Post - OASIS Please, Thank you
View Single Post
post #2 of (permalink) Old 12-13-2006, 12:41 PM
MOMBENZ
Hi,
Here you go:
OASIS RESULT:
1FMSU43P94EB83254
12/13/2006
07:40:42
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
31 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/11/2003 BUILD DATE
12/02/2003 SALE MILEAGE
00028
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0711 - USA 2004 NEW 60/100,000 PREMIUMCARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: STEPHANIE GOLDBERG-DUGAN
OPTIONS:
EXPIRATION DATE: 12/11/2008
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 09284
ESP CONTRACT START DATE: 12/11/2003
REPAIR HISTORY
06/01/2006
DEALER: Cambridge Classic Ford
WARRANTY CLAIM NUMBER: 070618 ODOMETER: 053358M
LABOR OP
CONDITION CODE
CONDITION DESC
9F452 TRANSDCR-EGR BACK PR 000 6005F 42 DOES NOT OPERATE PROPERLY
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F1
6C3Z 6C640A CONNECTION A/C DUCT 001 6005F1X1
6C3Z 6C640B CONNECTION A/C DUCT 001 12650D45
6C2Z 6K786AA CLAMP AIR COOLING 001 12650D81
6C3Z 6K786CA CLAMP AIR COOLING 002 12650D30
4C2Z 9B742A THROTTLE LEVER KIT 001 6646AH
000 MT9B742
EEC TEST. CODE PO299 PO478 PO488 P2262 P1408 P1335. RAN PIN POINT TEST. FOUN D CAC HOSE OFF EGR VALVE FAULTY AND EGR THROTTLE PLATE STICKING REMOVED AND REPLACED CAC TUBE AND CONNECTORS, REPLACED EGR VALVE AND EGRV THROTTLE PLAT E. CLEARED CODES AND ROAD TEST. ALL OK. CONDITION CODE 42 BASIC 9F452
05/03/2006
DEALER: Purvis Ford, Inc.
WARRANTY CLAIM NUMBER: 046785 ODOMETER: 051997M
LABOR OP
CONDITION CODE
CONDITION DESC
F2UZ 14526P FUSE-ELECTRICAL CIRC 001 12651D 42 DOES NOT OPERATE PROPERLY
5C7Z 19980AB CONTROL A/C 001 19700D1
000 19980A
AC AND ENTIRE INFOR CENTER INOP NO COOL NO FAN NO DISPLAY VERIFY NGS TEST EA TC UNABEL TO COMMUNICATEWITH MODULE PINTEST AND REPLACE FUSE RETEST P1259 SO LAR RADAR SENSOR CIRCUIT OPEN PINTEST SHOP MANU AL MONITOR PID DATA R&R CENT ER DASH PANEL TO GAIN ACCESS R&R EATC PERFORM MODULE INSTALLATION WDS RETEST AND ROAD TEST OK
1FMSU43P94EB83254 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-DEC-2003 11-DEC-2003 158499 USA 1 6K01 010601 3C3Z 16738 BD B63 39 1190
AWS Claim Key: 257373 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 09284 - * Name: BILL BARTH FORD, INC. Ph: 701-6639564 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2003 Doc #:131648A
Cust Comments: HAS MISSING HOOD LITE AND INSULATOR
Tech Comments: B TIME WIRED UNDER HOOD LITE UP TO BATTERY AND GROUNDED INSTALL HOOK INSULATOR
1FMSU43P94EB83254 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-DEC-2003 11-DEC-2003 158499 USA 8 2G05 031405 * RECAL * D42 42 22641
AWS Claim Key: 1507762 Trx Code: E84 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 09284 - * Name: BILL BARTH FORD, INC. Ph: 701-6639564 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:04-AUG-2004 Doc #:140503C
Cust Comments: LACK OF POWER WHEN COLD HESITATES WHEN TAKING OFF
Tech Comments: VERIFY ROUGH IDLE HESITATES AND LACK OF POWER COLDHOOK UP WDS RUN PERFORMANCE TEST REPROGRAM MODULE S PCM FICM AND TCM MT ROAD TEST TO RELEARN TRANNY SHIFT STRATEGIES
1FMSU43P94EB83254 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-DEC-2003 11-DEC-2003 158499 USA 9 5V01 0603XX * 1102 * N27 13 23092
AWS Claim Key: 1567371 Trx Code: E84 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 09284 - * Name: BILL BARTH FORD, INC. Ph: 701-6639564 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2004 Doc #:140844A
Cust Comments: BRAKES PULSATE WHEN APPLIED
Tech Comments: TEST DRIVE FOR BRAKE PULSATION FELT PULSATION ON FRONT AND REAR BRAKES MACHINE BOTH FRONT AND REAR BRAKE ROTORS ON VEHICLE REASSE TEST DRIVE AFTER MACHINING
1FMSU43P94EB83254 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-DEC-2003 11-DEC-2003 158499 USA 13 5V01 060301 1C3Z 1V125 AA N27 13 29472
AWS Claim Key: 2963507 Trx Code: P01 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 09284 - * Name: BILL BARTH FORD, INC. Ph: 701-6639564 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2004 Doc #:145746A
Cust Comments: CUST STATES BRAKES ARE PULSATING
Tech Comments: TEST DROVE VEH VERIFY CUSTOMER CONCERN FELT PULSATION COMING FROM FRONT AND REAR BRAKES COULD FEEL PULSATION IN STEERING WHEEL AND THROUGH SEAT REMOVEALL TIRES CK RUNOUT ON ALL FOUR ROTORS PLUS CK RO TOR THICKNESS REMOVE ALL FOUR ROTORS AND REPLACE WITH FOUR NEW ROTORS RETEST DROVE VEH NO BRAKE PUSATION FELT AT THIS TIME
1FMSU43P94EB83254 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-DEC-2003 11-DEC-2003 158499 USA 20 * * * * * * * 37714
AWS Claim Key: 6197655 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09284 - * Name: BILL BARTH FORD, INC. Ph: 701-6639564 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2005 Doc #:154508A
Cust Comments: RECALL 05S34
Tech Comments: 9079 PERFORMED RECALL 05S34 INSPECT WIREING HARNESS INSTALL FICM HARNESS REPAIR KITINSTALL ICP WIRE REPAIR KIT
AWS Claim Key: 6197656 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09284 - * Name: BILL BARTH FORD, INC. Ph: 701-6639564 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2005 Doc #:154508B
Cust Comments: RECALL 59B01
Tech Comments: 9079 PERFORMED RECALL 59B01 CUSTOMER ASSURANCE TEST DRIVE
1FMSU43P94EB83254 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-DEC-2003 11-DEC-2003 158499 USA 23 * * * * * * * 41300
AWS Claim Key: 7238422 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00061 - * Name: PURVIS FORD, INC. Ph: 540-8983000 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:07-OCT-2005 Doc #:031326A
Cust Comments: F.S.A. 05E15 E.P.SENSOR
Tech Comments: REPLACE EXHAUST PRESSURE SENSOR AS PER FSA 05E15D
AWS Claim Key: 7219918 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00061 - * Name: PURVIS FORD, INC. Ph: 540-8983000 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:07-OCT-2005 Doc #:031326B
Cust Comments: 59B01 ONE TIME CUSTOMER ASSURANCE ROAD TEST
Tech Comments: PERFORM ONE TIME CUSTOMER ASSURANCE ROAD TEST AS PER FSA 59B01A
1FMSU43P94EB83254 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-DEC-2003 11-DEC-2003 158499 USA 30 7H12 120403 5C7Z 19980 AB C05 42 51997
AWS Claim Key: 9290136 Trx Code: 0711D Labor Hrs: 1
Dlr Cd-Sub Cd: 00061 - * Name: PURVIS FORD, INC. Ph: 540-8983000 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2006 Doc #:046785A
Cust Comments: CK A C, & ENTIRE INFO CENTER INOP NO COOL, NO FAN, NO DISPLAY
Tech Comments: AC AND ENTIRE INFOR CENTER INOP NO COOL NO FAN NO DISPLAY VERIFY NGS TEST EATC UNABEL TO COMMUNICATEWITH MODULE PINTEST AND REPLACE FUSE RETEST P1259 SOLAR RADAR SENSOR CIRCUIT OPEN PINTEST SHOP MANU AL MONITOR PID DATA R&R CENTER DASH PANEL TO GAIN ACCESS R&R EATC PERFORM MODULE INSTALLATION WDS RETEST AND ROAD TEST OK
1FMSU43P94EB83254 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-DEC-2003 11-DEC-2003 158499 USA 31 1H03 030008 * 9F452 * D42 42 53358
AWS Claim Key: 9501635 Trx Code: E72 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 01692 - * Name: CAMBRIDGE CLASSIC FORD Ph: 740-4397767 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2006 Doc #:07061801
Cust Comments: CUST STATES THAT VEHICLE LOOSING POWER ANS SMOKES REAL BAD CONCERN CODE D42
Tech Comments: EEC TEST. CODE PO299 PO478 PO488 P2262 P1408 P1335. RAN PIN POINT TEST. FOUND CAC HOSE OFF EGR VALVE FAULTY AND EGR THROTTLE PLATE STICKING REMOVED AND REPLACED CAC TUBE AND CONNECTORS, REPLACED EGR VALVE AND EGRV THROTTLE PLATE. CLEARED CODES AND ROAD TEST. ALL OK. CONDITION CODE 42 BASIC 9F452
Thanks,
Vivian
MOMBENZ is offline
