59 Kenworth Wide Hood Re-power - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kblackav8or, this thread has received 6 replies and been viewed 2603 times.
post #1 of 7 (permalink) Old 07-25-2011, 09:22 PM Thread Starter
I do all my own stunts
Send a message via MSN to kblackav8or
I am getting ready to repower my 59 Kenworth CC-925 from a NHCT-270 to a Big Cam I 400. I still need a few things but the replacement engine runs and will be healthy when installed.
http://youtu.be/fXYhKzbIFv8
When done it will have a 5 x 3 and 4.11's on tall 24.5 rubber. Should move out nicely. The 270 runs great, it just isn't all that exciting. Eventually the truck will be fully restored and repainted.
2000 F-250 PSD 6 speed 4x4 Lariat
1959 Kenworth CC 925 NTC-400 5x3 4.10 SQHD's
Myriad of parts and pieces in my garage
kblackav8or is offline
post #2 of 7 (permalink) Old 07-26-2011, 02:32 AM
You want to check and see if the transmissions, clutch, and drive line will handle the extra torque.
Just a thought!
Johnp3 is offline
post #3 of 7 (permalink) Old 07-26-2011, 03:49 AM Thread Starter
Should be good to go. Main is going to be a twin countershaft Fuller 5 speed. Rears are late model SQHD's and I won't be hauling much. The aux could potentially be at risk but if I am responsible with how I use it, it should be fine. Would like to find a twin countershaft aux someday to match the main. Also looking for the somewhat oddball radiator to fill the grill of my early tilt wide hood. It isn't an A model hood, nor will an A model radiator fit.
My photo link has been unreliable for some reason but here it is:
http://www.supermotors.net/registry/22855
post #4 of 7 (permalink) Old 07-29-2011, 11:46 PM
379Longhood's Avatar
Have you measured a W900L rad? I thought that that hood only went on 8V 71 trucks
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #5 of 7 (permalink) Old 07-30-2011, 12:11 AM Thread Starter
That is news to me on the wide hood. Nobody has ever mentioned if there was a specific engine tied to the hood. I know they were for a larger radiator primarily. If I wanted to really confuse folks I could make it into an extended cowl truck and move the cab back about 10 inches or so. I have plenty of frame to do it. If I did that I would need to put something more exotic in there like a 12v71 or a 1693 or something else that is early big power. Not sure if a 900L radiator will fit either. I might be able to cheat though with bottom tanks from something else where they don't stick down so far.
post #6 of 7 (permalink) Old 10-03-2011, 02:28 AM
bmoeller's Avatar
Sell the blue KW then?
"Obama = Hoax and Chains"
bmoeller is offline
post #7 of 7 (permalink) Old 10-03-2011, 03:23 PM Thread Starter
I sold my blue 81 last fall and bought the 59 in December. After I get the drivetrain the way I want it, it will be getting new paint.
Wide wheels JMS8800 General Ford Truck and Excursion 3 08-20-2007 01:51 PM
Wide Screen TV Tech Guy The Parking Lot 11 11-17-2006 12:23 AM
Wide-Track Cooper443irty 2008-2010 6.4L Power Stroke 4 10-02-2006 04:43 PM
wide open miss (bad) elkhunt2 5.9L Cummins (1998.5-2002) 4 04-23-2006 07:07 AM
