86 freightliner - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by m0t0x66, this thread has received 14 replies and been viewed 4085 times.
post #1 of 15 (permalink) Old 02-10-2012, 01:46 PM Thread Starter
86 freightliner
Hey guys
Just thought i would show off my truck in here. She's nothing too special but she's paid off and makes me a living. Mainly came to the forum to get some info from the experts. Its coming time for an overhaul for the old 400 big cam and i wanna get some more power outta the old girl. Not sure which cpl it is I'll have to check it out tonight
Sent from my SCH-I500 using Tapatalk
m0t0x66 is offline
The Following 2 Users Say Thank You to m0t0x66 For this addition to TDG:
379Longhood (02-20-2012), LOG HAULER (02-26-2012)
post #2 of 15 (permalink) Old 02-11-2012, 03:07 PM Thread Starter
Its a cpl642
m0t0x66 is offline
post #3 of 15 (permalink) Old 02-11-2012, 03:29 PM
CR Toney's Avatar
Add a dual fuel line to the front head for 25 hp a fass gives another 25. Make sure you change your vibration damper when you do an overhaul. Could add a crank balancer too.
'95 T800 N14 13sp DO 4.33 gears
'89 W900B 444 Cummins CPL 1280 18sp 3.55 w/2sp axles 19ft CIM grain/silage box
'03 Dodge 2500 4x4 6sp modded just right
'05 Dodge 3500 4x4 6sp w/ Triple C hydra bed
Smarty Touch Centramatics ATS ex manifolds
'06 IH 4300 DT466 Alison 245HP
Authorized Ekotuning.com dealer
CR Toney is offline
post #4 of 15 (permalink) Old 02-12-2012, 02:00 AM
justdoug's Avatar
Great looking older truck,paid for,makes money.........WHAT'S NOT TO LOVE!?!?!
-Doug
justdoug is offline
post #5 of 15 (permalink) Old 02-12-2012, 01:18 PM Thread Starter
yeah shes a good old truck
m0t0x66 is offline
post #6 of 15 (permalink) Old 02-12-2012, 07:21 PM
SmokinCAT's Avatar
Loooking good, it's nice to see older trucks still on the job.
Getting a little more power out of her is relatively simple, you can do the dual fuel lines, but I would save the $700 dollars on the FASS and buy a decent set of injectors, that will net you more than 25hp for less money. Let me know if you want to go that route.
I had good luck and was pleased with the results when I did injectors, and that was with a pump with stock settings, I feel it is safer to leave the pump set at stock and get more fuel into the cylinder instead.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #7 of 15 (permalink) Old 02-12-2012, 10:36 PM
justdoug's Avatar
Is that because you don't think the FASS works? I was always under the impression those units(and others like them)were originally designed to work on PT pump motors.
-Doug
justdoug is offline
post #8 of 15 (permalink) Old 02-12-2012, 11:11 PM
SmokinCAT's Avatar
The way I look at it is that if you are starving a PT gear pump for fuel you have other problems, the way the gear pump is setup it will only pump and pull what it needs, there is no reason to force feed it.
An engine that relies on a supply pump likes say a B/C cat responses well to a well pressurized flow and actually need it. I see a point and time that it may be needed, but no one outside the electronic cat crowd will ever trash the HP level that it would require a feed pump to maintain power.
Cody.
4.11 SQHP rockwells
post #9 of 15 (permalink) Old 02-12-2012, 11:22 PM
justdoug's Avatar
I see,i always thought they were supposed to take air out of fuel. I guess i'm thinking of the fuel preporator. Do they even make them anymore?
-Doug
justdoug is offline
post #10 of 15 (permalink) Old 02-12-2012, 11:47 PM
SmokinCAT's Avatar
Yeah, they are even more expesnsive. The gear pump in a way does the same thing as either pump. I seriously doubt anyone has proven the claim of 25hp on the dyno, and it they did it was done along with a pump tweak as well, because all the fuel to the injectors is still limited by the pt system.
Cody.
4.11 SQHP rockwells
The Following User Says Thank You to SmokinCAT For this addition to TDG:
justdoug (02-13-2012)
Freightliner 120 Velocity Medium and Heavy Duty 2 10-15-2011 12:38 AM
Freightliner FL-60 Strouty Medium and Heavy Duty 18 07-25-2010 11:49 PM
93 freightliner only builds 70 psi.??? horse man Medium and Heavy Duty 2 06-16-2009 02:55 AM
freightliner help coyle246 Medium and Heavy Duty 7 09-07-2007 08:00 PM
I've Got Me a Freightliner FL-70 Up-n-Cummins Medium and Heavy Duty 8 01-20-2006 07:56 PM
