85 Autocar Contrucktor 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sean999r, this thread has received 13 replies and been viewed 4387 times.
post #1 of 14 (permalink) Old 04-08-2013, 05:55 PM Thread Starter
sean999r's Avatar
Just bought this Acar, it's really a re-branded / slightly improved former White Roadboss 2, which after the 80 or around that time I believed they (Volvo / White / Autocar) killed off the RB2 which became the new Construcktor 2 which they refer to in the repair manual as K series !!??
It was a former water truck for construction company has spent it's time in the Denver area. Here is its base spec outline
Std heavy varying depth section 3/8 frame
FA 14,600 multi leaf w/ twin shocks
RA 58k SSHD on Hendrickson RS rubber block
445hp 8V92TA Detroit Diesel
15sp Fuller
1500 sq/in radiator
Overall it's in very good condition, hood is really good, interior is rough and horrible tan saddle color, truck was originally red / orange mono chromatic frame & cab. The truck sat for 4 yrs, I arrived hooked up 2 old car batteries, checked fluid levels, quick squirt ether, it fired right up, sounded great.
I'm going back in couple weeks time change oil filters & coolant, mount up taillights and mudflaps drive it back to MT.
sean999r is offline
post #2 of 14 (permalink) Old 04-08-2013, 06:00 PM Thread Starter
sean999r's Avatar
Here couple other pics, had trouble loading on first post
sean999r is offline
post #3 of 14 (permalink) Old 04-08-2013, 06:23 PM
Aimless Wanderer
Looks like you have something to work with there. The 8V92's could be a problem but that late in the game it's probably a "Silver" series which were pretty good engines.
Backslap is offline
post #4 of 14 (permalink) Old 04-08-2013, 06:28 PM Thread Starter
sean999r's Avatar
Thanks, it's a silver, DD get a bad rap, there a lot better than most the haters will know.
sean999r is offline
post #5 of 14 (permalink) Old 04-08-2013, 06:47 PM
Aimless Wanderer
I like them myself. Still have several in service.
Backslap is offline
post #6 of 14 (permalink) Old 04-09-2013, 08:10 AM
SmokinCAT's Avatar
Looks very similar to the white road boss.
Are you saying that anyone that has had a bad experience with a Detroit is automatically a hater?
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #7 of 14 (permalink) Old 04-09-2013, 02:04 PM Thread Starter
sean999r's Avatar
No, re DD. just purchased couple Autocar sales brochures, 83 Construcktor 2 owners book & workshop repair, Volvo/White/Autocar killed off the RB2 RoadBoss name along with the Autocar U series, improved it some what and relaunched / rebranded the RB2 as the Autocar Construcktor 2, the repair manual refers to as K series. They had 3 BBC lengths with 2 axle Set Back options in the late 70's, think the options were reduced in the 80's, 83 owners book only mentions 2 BBC.
sean999r is offline
post #8 of 14 (permalink) Old 04-09-2013, 02:12 PM Thread Starter
sean999r's Avatar
sean999r is offline
post #9 of 14 (permalink) Old 04-11-2013, 10:34 PM Thread Starter
sean999r's Avatar
Think the previous owner has a problem with numbers, dyslexia (which I also suffer ) was told its an 85, the CO title just arrived and its an 83, well that matches the yr list on the engine valve cover but, when checking engine model # that turn out to be a non-highway / industrial listing ? Called helpful Volvo SLC dealer, there computer system couldn't check VIN for model # but it did throw up a parts listing. So from my deductions I think it's model number is either
WKM64 of more likely WKM64F, F for forward set axle.
Located a complete chrome grill surround for $100 + shipping it will need re-plating.
Pre home trip:-
Cleaned & polished up a pair Alcoa S/Single 12.25 wheels with 425/65 Yokohama tires, these I will mount on steer, then I can select best of the rest 11R24.5 wheels for the drivers.
Charged up pair of new but stored 12v truck batteries, all I need now is 10 gallons Delo 100 40wt, filters, make a QD hook up taillights & mudflaps which mount on a 2x4 wire tie to frame.
sean999r is offline
post #10 of 14 (permalink) Old 05-05-2013, 04:26 PM Thread Starter
sean999r's Avatar
Just spent a day working on my Acar
Installed new batteries, 12.25 super-singles on steer, swapped out 2 really bad drive tires with the ok old steers, rigged up temp' mudflaps, clean the inside. Just need change filters and engine oil, couldn't find correct 40wt, so have do this when go back for final time in June when it will make its maiden trip home to Bozeman following its 7 years of rest
sean999r is offline
8.3 Cummins in a 1948 Autocar autocartodd Diesel Conversion 1 09-04-2012 03:47 AM
Autocar truck parts jmpool Medium and Heavy Duty 1 11-16-2010 10:29 PM
Classic AutoCar.. ZeCatfish Medium and Heavy Duty 15 08-09-2010 12:08 AM
Hot rod Autocar itali83 Heavy Duty Rebuilds / Rides 4 03-20-2010 12:22 PM
1999 Volvo Autocar Scubba Medium and Heavy Duty 0 04-11-2009 09:32 PM
