93 pete sleeper - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sexytrkr, this thread has received 8 replies and been viewed 5375 times.
post #1 of 9 (permalink) Old 04-11-2014, 02:40 AM Thread Starter
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
93 pete sleeper
my truck has a small sleeper on it. Its not a unibuilt so i pretty much sit straight up. has anyone ever cut the cab behind the seats?
i was thinking of doing this and using an accordian gasket they use on truck campers......not sure if I would affect the structure of the cab if I did this or not.
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline
post #2 of 9 (permalink) Old 05-05-2014, 01:02 AM
379Longhood's Avatar
I am pretty sure one of our members (black '89 flattop) put a unibilt opening/frame in a frame mounted sleeper truck
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #3 of 9 (permalink) Old 05-05-2014, 08:45 AM
SmokinCAT's Avatar
You can do the large cut out for the room, but the structure underneath isn't there to build as a true unibilt.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #4 of 9 (permalink) Old 05-05-2014, 02:31 PM
Yeah don't try that, there are quite a few extra braces etc, in a true unibilt cab,
JD 820 black dash
post #5 of 9 (permalink) Old 05-07-2014, 01:01 AM
hi, I fitted kenworth 60 inch to a mack r model cab. it can be done, just dont go through floor supports, and not all way to roof. its not what you do, but how you do it. how big is opening that is all ready there? make the sleeper fit that?
Grant
ducky698 is offline
post #6 of 9 (permalink) Old 05-07-2014, 01:22 PM
His sleeper fits, it is just the leg room issue in almost all class 8 day cab trucks, early Peterbilts had a frame mount walk in sleeper, later ones had an unibilt option where there were brackets and bracing to make the cab and sleeper an air ride unit as well as a wider opening that the seat could move back into. the stupid thing about the Pete room issue is the pedals could easily be several inches forward. What are all truck cab engineers 4'10" tall ???
JD 820 black dash
The Following User Says Thank You to 379Longhood For this addition to TDG:
cowpuncher (05-10-2014)
post #7 of 9 (permalink) Old 05-09-2014, 07:39 PM Thread Starter
truckn'
sexytrkr's Avatar
I just want to open the opening wider so i can lean my seat back......I dont care about the unibilt part.
sexytrkr is offline
post #8 of 9 (permalink) Old 05-09-2014, 11:13 PM
prolly the easiest route is to get a unibilt opening frame and fit it to your cab the boot should also work , not much movement on frame mounted sleepers,
the member that did the conversion is 3406bcat, maybe search his threads,
JD 820 black dash
sexytrkr (05-10-2014)
post #9 of 9 (permalink) Old 06-07-2014, 01:30 AM
Yes you can do er, I have a 92 kw aerodyne, same problem as yours, same build I think, anyway I had four states cut the wall out on the cab and sleeper and put a unibuilt frame and boot in it, they also cut some of the cab net on the driver side to make more room, way more room, I moved the seat back 4 inches and you could move it more, the boot is $750 plus dollars and the frame wasn't that much, they took the sleeper off on mine, Don't have them do a thing!! They do shiet work and are not mechanics, they only do good work if your spending big bucks, they wouldn't let me see the bill until I paid for it, anyway $9200 for that and a junk fifth wheel .. install and some other piddle crap... There a JOKE!!!!
TIZDEEP is offline
The Following User Says Thank You to TIZDEEP For this addition to TDG:
w9l (06-22-2014)
looking for a 36 inch sleeper for a 359 pete bulldawg1081 Medium and Heavy Duty 7 10-26-2013 02:53 PM
KW sleeper a/c ? justdoug Medium and Heavy Duty 3 06-12-2012 01:52 PM
sleeper Bcarriveau The Parking Lot 21 02-01-2008 08:03 PM
Now this is a sleeper danster The Parking Lot 19 12-21-2007 11:03 PM
The sleeper look. BigBlue Ford - Modification instructions, Product installs and Tech Articles 4 10-22-2005 01:29 AM
