1987 W900B - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SmokinCAT, this thread has received 10 replies and been viewed 5011 times.
post #1 of 11 (permalink) Old 03-17-2015, 08:34 PM Thread Starter
SmokinCAT's Avatar
1987 W900B
Acquired a new truck on the farm this past week, traded the 83 K100 for it.
It is a 87 W900B with a 444 in it that has been converted to high flow cooling and air to air. Factory 254" wheelbase.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
The Following 2 Users Say Thank You to SmokinCAT For this addition to TDG:
Caterbilt (04-20-2015), LOG HAULER (06-08-2015)
post #2 of 11 (permalink) Old 03-20-2015, 01:24 AM
379Longhood's Avatar
that is an interesting set up it should work fairly well I would think.
I see the tow yoke in the bumper to help with the 8 bag
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #3 of 11 (permalink) Old 03-20-2015, 06:24 AM Thread Starter
SmokinCAT's Avatar
It was just in case, between the thaw and the 2.5" of rain the day before it was questionable what it was going to do, but we ended up not having to hook to either end.
Cody.
4.11 SQHP rockwells
post #4 of 11 (permalink) Old 04-06-2015, 07:22 AM Thread Starter
SmokinCAT's Avatar
Cody.
4.11 SQHP rockwells
The Following User Says Thank You to SmokinCAT For this addition to TDG:
post #5 of 11 (permalink) Old 04-07-2015, 06:00 PM
I like it!... a lot. You'd have me rubbernecking if I saw it out on the road. Especially in the rear view,
Caterbilt is offline
post #6 of 11 (permalink) Old 04-07-2015, 06:11 PM Thread Starter
SmokinCAT's Avatar
Thanks, it's going to get aluminums put back on the drives soon might look just a little better.
I wasn't a huge fan of the 900B but this truck is kind of growing on me. Had to do some engine work to try and clean some of that smoke up, it was smoking almost as bad as it is in this picture at a warm idle.
Cody.
4.11 SQHP rockwells
post #7 of 11 (permalink) Old 04-22-2015, 02:20 AM
Still Diggin
KWT800's Avatar
That truck does look nice, I can't ever find any nice old kw's here. Maybe for the best though or our farm would start to look like vanderhaags.
KWT800 is offline
post #8 of 11 (permalink) Old 04-22-2015, 08:24 AM Thread Starter
SmokinCAT's Avatar
Only way we ended up with this truck was a trade, normally it wouldn't have been something that would have even been looked at.
It has been getting worked though, as the freightliner has been down having the new transmission replaced under warranty.
The engine is not a 444 but rather a big cam 3 that was swapped in, which having standard injectors doesn't hurt my feelings at all as I did put a set of injectors in it a couple of weekends ago, setting them was a pain as the accessory drive isn't in time so I had to set them at peak lift and use a traditional torque wrench to 72in-lbs.
Cody.
4.11 SQHP rockwells
post #9 of 11 (permalink) Old 05-25-2015, 09:46 PM
Nice truck Cody, a guy I know had a BCIII converted to air to air and some other little things, my guess was around 500 hp.
another guy in Miami had a BCIII with the heads from a N14, the mechanic shop he took it to could never figure out how they did it, he told me the hole bores in the block don't match and the N 14 head has more bolts to hold the heads down than the BCIII.
later he told me he asked the guy, and said he had some body that owns or work at a machine shop and fill the holes back and re drilled them, I still can wrap my head around that but very intriguing, it was on a nice T600 and the owner said he would not trade it for anything and if he had to get rid of it he would keep the engine.
H800T is offline
post #10 of 11 (permalink) Old 05-25-2015, 10:56 PM Thread Starter
SmokinCAT's Avatar
I'm not sure if trust that story too much, the 855 and N14 use the same head gasket. Now the N14 electronic heads are different height and the o-ring spacing on the injectors are different as well.
Cody.
4.11 SQHP rockwells
87 w900b cdwood388 Medium and Heavy Duty 2 11-09-2012 03:53 PM
1987 Kenworth W900B Parting Out or Buy as a Project HillbillyDeluxe Everything Else 0 07-29-2011 10:50 PM
Lowering Frontend on W900B HillbillyDeluxe Medium and Heavy Duty 20 06-23-2011 11:07 AM
new to me '89 W900B CR Toney Medium and Heavy Duty 15 04-28-2011 10:07 PM
'87 W900B Rear Susp. / Diffs HillbillyDeluxe Medium and Heavy Duty 12 03-23-2011 03:50 AM
