which O2 sensor is which? need to replace 2 of 4 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SSpeeDEMONSS, this thread has received 14 replies and been viewed 5484 times.
post #1 of 15 (permalink) Old 10-25-2010, 10:14 PM Thread Starter
SSpeeDEMONSS's Avatar
its a 2000 2500 6.0 vortec. i went to smog it and it failed due to 2 oxygen sensors. passed the actual smog though. the codes it has are P0141 and P0161. O2 sensor heater fault(bank 1 sensor 2 and bank 2 sensor 2). are those both the post cat sensors? once i replace them, how can i clear the codes?
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #2 of 15 (permalink) Old 10-25-2010, 11:05 PM
Gone Fishin...
merlin5577's Avatar
Yes, both of those are the rear (post cat) sensors. When replacing them, disconnect the battery and then after 2 complete ignition cycles the light should go out.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
The Following User Says Thank You to merlin5577 For this addition to TDG:
SSpeeDEMONSS (10-26-2010)
post #3 of 15 (permalink) Old 10-26-2010, 01:24 AM Thread Starter
thanks! that will be simple.
post #4 of 15 (permalink) Old 11-15-2010, 08:23 PM Thread Starter
i replaced the sensors, had the battery unhooked when i did so, and the light is still on. what gives?
post #5 of 15 (permalink) Old 11-15-2010, 08:42 PM
Gone Fishin...
merlin5577's Avatar
Like I said, it will take a few ignition cycles for the light to go out. Drive the truck for a few days and the light should go out.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #6 of 15 (permalink) Old 11-16-2010, 05:17 PM Thread Starter
i changed them out on friday and been driving around and the light is still on.
post #7 of 15 (permalink) Old 11-16-2010, 06:03 PM
Gone Fishin...
merlin5577's Avatar
Have the codes pulled again and see if its still the 02 sensors. My Suburban had the same codes a few years ago and thats what I did to fix the problem.
Not to sound like a wise ***, but you did plug the sensors in when you installed them, correct?
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #8 of 15 (permalink) Old 11-17-2010, 03:55 PM Thread Starter
haha. yes, theyre plugged in and clipped. i guess ill have to rent a scanner from autozone to check them then.
post #9 of 15 (permalink) Old 11-18-2010, 01:03 AM
496 Cubic Inches
496 BB's Avatar
Go over to Johnnys house and use EFI Live.
2001 HD 8.1L 4x4 Crew SB LT
EFI Live, K&N CAI, MSD, Plug mod (in testing), 160* T-Stat, Flomaster 40 Series SS (Duals)(No tails), Custom H-Pipe, (2) RF P2410's in custom down fire box, Rockford Old Skool 250aii amp, AirLift bags, On board compressor, Custom mount gauges, Body colored trim, 285 Revo ATV's, 16x10 Ions, 6K HID Lows & Fogs, Blue LED Dash, Blue LED Switches, Blue LED Footwell Lights, Blue LED Interior Lighting, and so much more....
Some people are like Slinkies ... not really good for anything, but you can't help smiling when you see one tumble down the stairs
Better to remain silent and be thought a fool, than to speak and remove all doubt
496 BB is offline
post #10 of 15 (permalink) Old 11-18-2010, 04:39 PM Thread Starter
thats too much work and the old guy never answers his phone.
7.3L IDM replace, need help. jimbotismo 1994-2003 7.3L Power Stroke 14 01-12-2012 03:14 PM
How to remove and replace ICP sensor on 6.0 rickou812 Ford - Modification instructions, Product installs and Tech Articles 1 01-26-2011 12:19 AM
96 CPS replace Burner718 1994-2003 7.3L Power Stroke 3 02-26-2009 03:42 AM
Cat 3116e: Fuel Temp Sensor & Boost Pressure Sensor probablecause Medium and Heavy Duty 0 02-03-2009 01:54 AM
Replace cat or not lilgsx 2003-2007 6.0L Power Stroke 8 11-28-2005 02:18 PM
