2.8 S10 keeps dying - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by OverPressured, this thread has received 1 replies and been viewed 2355 times.
post #1 of 2 (permalink) Old 12-15-2010, 07:12 AM Thread Starter
2.8 S10 keeps dying
I just recently bought a 86 s10 with the 2.8 tbi v6. its 4x4 and 5sp. It starts and runs fine for about 30 seconds to a minute then it just dies. I have 10-12 psi of fuel pressure from start up till it dies and it even holds 10psi after it dies till the fuel settles back down the line. For the short amount of time it does run it idles smooth, not rough. Im kinda lost on what my issue might be. Any ideas??
OverPressured is offline
post #2 of 2 (permalink) Old 12-22-2010, 06:31 PM
Location: Freedom, Ohio is where home is but I'm currently in the dreaded southern Hemland Province, Afghanist
Just went thru the same thing with a friend's Grand Am. Not sure where your local is but fuel pumps are known to go during the winter time. Try replacing the fuel filter to see if you have a fuel blockage there. Thats a cheap fix, if that doesn't cure the problem then it could very well be the fuel pump is going.
2010 Ford F150 XLT 5.4V8 Superchips, cold air intake, flowmaster dual exhaust
2008 Ford F350 Lariat Dually 22,000 miles Bad injectors, turbo's, and had a new DPF. traded in on the gasser.
2004 Ford F350 Lariat Dually 44,000 miles lemon EGR, two turbo's
Done with diesel's for now. Lost my @#$ on the two we had. 40 times in the shop between the both of them.
Michael Selander
Help the garage!
CAN YOU KEEP UP?
BIGHILLBILLY is offline
Need some help truck dying Cummins02 Duramax 2001-2004 (LB7) 2 07-29-2010 02:06 AM
need help my dog is dying AUSSIEDAVE The Parking Lot 40 03-24-2010 05:44 AM
I think my transmission is dying.. HELP!! Stroker01 1994-2003 7.3L Power Stroke 10 02-18-2010 03:14 AM
Tranny dying... BigRed97 1994-2003 7.3L Power Stroke 13 06-11-2007 08:11 AM
OT - Dog dying... John_G The Parking Lot 25 08-13-2006 04:46 PM
