02 Chevy 3/4 ton sucking in gas tank. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by geok, this thread has received 2 replies and been viewed 3256 times.
post #1 of 3 (permalink) Old 11-21-2012, 01:01 AM Thread Starter
A fellow I know has a 02 chevy 3/4 ton with a 6.0. After he starts and runs it for for a few minutes, it starts collasping the gas tank. If he leaves the gas cap off, it doesn't have any problems. What is causing this? Thanks,
geok is offline
post #2 of 3 (permalink) Old 11-21-2012, 10:59 PM
Man. Trans 2wd Enthusiast
I believe they had a evap canister near the fuel tank on GMT800 vs the underhood one on the GMT400. the GMT800 canister was very easily clogged by dirt road travels.
this is all recycled info, but I have heard it numberous times, so I feel it is somewhat correct.
good luck!
99 Chev C3500 6.5L NV4500 14 bolt 2wd 4.10 130K White Ext, Gray Int. RC159.5" WB DRW Chassis Cab with utility box Runs Great, building up
96 GMC C2500HD 6.5L NV4500 14 bolt 2wd 3.73 240K White Ext, Blue Int. ECLB 155.5"WB SRW Pickup runs bad, getting motor right now
95 GMC C2500HD 6.5L NV4500 14 bolt 2wd 4.10 135K White Ext, Grey Int. RC 131.5"WB SRW Pickup with utility box runs strong, yet huffs on 1 hole
95 Chev C3500HD 6.5L NV4500 D80 2wd 5.13 132K White Ext, Grey Int. RC 159.5"WB DRW Chassis Cab with flatbed bad heads, needs motor re-do
94 GMC C2500HD 6.5L 4L80E 14 bolt 2wd 3.73 300K White Ext, Blue Int. Suburban needs engine
91 GMC C1500, 6.2L SM465 10 bolt 2wd 3.42 59K Red Ext, Red Int. RCLB 131.5"WB SRW Pickup needs injectors, oil cooler lines
91 Chev C1500 4.3L 5LM60 10 bolt 2wd 3.42 ??K White Ext, Red Int. RCLB 131.5"WB SRW Pickup needs...alot
Dad's:
98 GMC C3500 5.7L Vortec NV4500 208K down right now, needs head gaskets (dex cool claims another set! )
92 GMC C3500HD 6.5L Turbo NV4500 160K needs exhaust system and oil cooler lines
93 GMC C3500HD 6.5L Turbo 4L80E 260K had a crate 6.5L sometime
All above are 159.5" C&C, 10'-12' flatbed, Summit white, RC, SL trim, 2wd
96 GMC C2500HD SL ECLB 6.5L 5spd 2wd. 215K (sold to dad, ran good for a bit, started missing at idle, had blowby since purchase
84 Pete 362 COE, 300 BCIII RTOO 13 spd Fuller (3 OD ratios, hard to find) Single axle tractor, air seats, cab, suspension, OEM twin 200 gallon tanks.
74 Pete 352 COE, cat, 13spd TS, B&H grain truck
90 Marmon 57P long hood conventional, 60"flattop, 12.7L60 Series, 13 spd fuller, TS tractor
76 Marmon COE 8V92T 13spd fuller, TS B&H grain truck
95 IHC 9600 COE M11, 10 spd, SA tractor.
GM Guy is offline
post #3 of 3 (permalink) Old 11-07-2013, 01:35 PM
Send a message via Yahoo to steved
Could even be a bad gas cap...
SOLD - 2004.5 2500 Ram, 600CTD, NV5600, 4.10s, FASS'd, Dynatrac Free-Spin Kit, Gulf Coast 0-1 bypass, Intake and Exhaust.
New - 2012 Chevrolet Silverado 2500HD, 6.0L, 6spd auto, 4wd, 3.73s..
steved is offline
MBE 4000 sucking air... leftlanetruckin Medium and Heavy Duty 25 03-20-2011 01:13 PM
Horsepower Sucking Fan argo 6.2L Diesel Engine 6 10-07-2010 11:11 PM
Airdog 100 sucking air cowboytw13 5.9L Cummins (1998.5-2002) 24 01-08-2009 11:06 PM
Sucking Fuel On 8v71 King of Obsolete Medium and Heavy Duty 8 01-16-2008 12:42 AM
Turbo Sucking Air imported_deerhunter Duramax 2006-2007(LBZ & LLY) 4 01-11-2008 05:00 PM
