Scotts L2048 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 8 replies and been viewed 3620 times.
post #1 of 9 (permalink) Old 07-07-2011, 05:13 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Scotts L2048
Went to mow grass last night, mower dead, so I tried to charge the battery but it tested bad, so off to autozone for a new battery... Put it back on and thought the starter was very weak. Got the grass cut and shut it off in the driveway.. This is where I went wrong.. It would not start. Did some checking and found the solenoid to be bad. So I thought what the heck Ill just jump across the solenoid and get it put away, this is when I found yet another problem.. Starter locked up. I feel this a been coming for a while since the starter has gotten much weaker and took more juice to get it going. SO I started pulling it apart last night and here is what I found.
This is what it took..
[IMG][/IMG]
To get this off..
[IMG][/IMG]
So my question, at what point did someone think a plastic bendix on a starter was a good idea?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 9 (permalink) Old 07-11-2011, 12:20 PM
hey, maybe its abs plastic....or polypropylene, or high density polyethylene....or saran wrap........sorry couldn't resist. If you don't laugh you'll cry. Did you get it fixed?
89greendiesel is offline
post #3 of 9 (permalink) Old 07-12-2011, 03:27 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Yeah its fixed. Starts a whole lot better now too.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #4 of 9 (permalink) Old 04-07-2012, 04:02 AM
Let me guess it's a Briggs and Stratton engine, Mine needed a new drive ever year.
later is offline
post #5 of 9 (permalink) Old 04-07-2012, 04:21 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
yeap, however its still going strong now.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 9 (permalink) Old 04-07-2012, 02:03 PM
The first one I had go out, I ask the parts guy why it was plastic? His response was that it is easy to change the starter drive, but not the flywheel gear. So it was made that way to save the flywheel.
You may want to keep a spare on hand.
later is offline
post #7 of 9 (permalink) Old 02-10-2013, 04:30 PM
Bolt
gardentractor's Avatar
The parts man was right that is why they are plastic. They have to consider idiots that own them and try to start them while they are running.
2000 F350 4X4 Powerstroke red 6spd reg cab stock for now...
1988 Chevy IROC-Z camaro black 5spd 305 55,000 orig miles, my baby
1988 Chevy 4x4 350 ext long bed
1980 Gmc 4X4 modified 350 k20 flatbed 4spd
1956 6400 Chevy 235 6 cyl
gardentractor is offline
post #8 of 9 (permalink) Old 02-10-2013, 04:40 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
I have since rebuilt the transmission in it. A planetary gear grenaded and went thought the bottom pan. Put some other new parts in it and it rolls on strong.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #9 of 9 (permalink) Old 02-10-2013, 06:09 PM
Weld engineer's Avatar
And there are a lot of idiots out there who ruin it then complain that the company made a piece of junk that's expensive to repair/replace. Old cub cadets are still the best! Starter/generator via belt lasts forever.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
