Chainsaw chain sharpening - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fahlin Racing, this thread has received 5 replies and been viewed 1876 times.
post #1 of 6 (permalink) Old 01-22-2014, 06:02 PM Thread Starter
Fahlin Racing's Avatar
Sharpening your saw, with all the chain sizes out there you need the right round file or some call them rat-tail files. You only cut in one direction, pushing away from your body. The usual stroke count suggested is 3, I believe it depends how much pressure the person doing the work applies since that will dictate the amount of material cut. We will just stick with 3 strokes for this.
First off, have gloves, look at the teeth and see how much work is needed before you start. Select your file, larger size saws use larger designed tooth and chain layout, smaller saws use smaller designed tooth and chain layout.
Tools
File set
File brush
File holder
Flat file
Here is the file holder I have, which is STIHL, which is the saw brand I have as well for my main chainsaw.
Notice I have it at an angle, the file holder also has angle designations to help stay with the direction needed to sharpen the tooth. Pushing away, keeping your file moving STRAIGHT ahead horizontal to the chain at the angle needed. DO NOT angle the file upwards or angle it downwards or you will just end up going to the hardware store to purchase your new chain if it takes you are chain to get it down. BE PATIENT!!!
When you have a dull chainsaw chain, you will notice your saw slowing down and catching on the log/branch. Your wood chips will be saw dust when the dull blade is cutting as well. You can gauge your chain's effectiveness by the size of the chips coming out after the wood has been cut by the tooth.
The easiest way to sharpen, unlock the bar-lock so the chain can move freely by hand, there are things out there that can be used to sharpen chains without the saw, but, you mostly see them at machine/blade sharpening shops.
The other way to sharpen is to use a electric sharpener. I will post a picture of one that I bought from a neighbor and plan on using later.
Remember, gloves, correct file and patience. Good luck & stay safe.
Jim "Iron Giant" Fahlin ~ A high performance car is like a guitar, you have to tune it to achieve your best operation and pull ahead of the competition.
Gas & Diesel Motorsports
Heavy Equipment/Truck/Trailer parts Specialist
Zeigler Diesel Perf
Socal Diesel
Fahlin Racing is offline
post #2 of 6 (permalink) Old 01-27-2014, 03:36 AM
Did you know they make tungsten carbide tipped chain saw chains now?
later is offline
post #3 of 6 (permalink) Old 01-28-2014, 09:49 AM Thread Starter
Did not know that, I will have to check it out at the hardware store next time I am able to.
Zeigler Diesel Perf
Socal Diesel
post #4 of 6 (permalink) Old 01-28-2014, 01:46 PM
Old Fart
dbennett48's Avatar
Stihl's is called a Demolition Chain. FIrefighters use them to vent roofs and enter buildings. Brutal and expensive.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
post #5 of 6 (permalink) Old 01-29-2014, 01:32 AM
Weld engineer's Avatar
The terminator.
http://carbidechainsaw.com/linkterminator.html
Some toolmaker got crazy with the carbides at work one day.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #6 of 6 (permalink) Old 02-21-2016, 12:45 PM Thread Starter
Figure I would finish this out for anyone interested. I will still try to get my bench mounted sharpener going also even if people out there don't want to fork out the money for a carbide chain or just learn to maintain a tool/build skills.
When adjusting your chain tension, remind you the bar needs to be loose enough for the adjuster to function but not excessively loose, sometimes that aspect is forgotten.
With each saw brand or even the size of it in general there may be a different method to adjust tension. My saw has an accessible adjustment screw in the middle of the side cover that retains the bar and chain in between the two nuts that retain these pieces. There is also your plastic chain-guide inserts along with your oiling port for chain lubrication under this cover.
Zeigler Diesel Perf
Socal Diesel
Chainsaw chain tightening Fahlin Racing Small Engines 0 01-22-2014 05:22 PM
Chainsaw problems Lonesome7.3 The Parking Lot 9 12-21-2013 04:20 PM
aussiedave's chainsaw carnage AUSSIEDAVE The Parking Lot 37 07-31-2009 04:13 AM
need a chainsaw Rcannon The Parking Lot 51 04-18-2007 11:33 PM
Chainsaw! cmkworm The Parking Lot 35 05-12-2006 02:14 AM
