2013 Ram - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 15 replies and been viewed 9425 times.
post #1 of 16 (permalink) Old 09-28-2012, 01:57 AM Thread Starter
Dodgefarmer's Avatar
2013 Ram
Here is a link to information on the 2013 Ram http://www.allpar.com/trucks/ram/201...y-pickups.html
The Cummins ratings depending on model and how equip.
Horsepower
@ rpm
Lb-ft @ rpm
Required
Transmission
Cummins Diesel
385 @ 2,800
850 @ 1,600
Aisin ASC69RC (Ram 3500)
Cummins Diesel
350 @ 2,800
660 @ 1,500
Six-speed manual
Cummins Diesel
370 @ 2,800
800 @ 1,600
68RFE six-speed automatic
singles club # 198
Dodgefarmer is offline
The Following 2 Users Say Thank You to Dodgefarmer For this addition to TDG:
Eazydeezy (10-05-2012), HLC2239CUMMINS (10-03-2012)
post #2 of 16 (permalink) Old 10-02-2012, 04:32 AM
ADMIN/MAFIA
neeltburn's Avatar
Glad to see them keep the manual trans!
Sent from my iPad using smoke signals.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 16 (permalink) Old 10-03-2012, 09:04 PM
HLC2239CUMMINS's Avatar
Horsepower
@ rpm
Lb-ft @ rpm
Required
Transmission
Cummins Diesel
385 @ 2,800
850 @ 1,600
Cummins Diesel
350 @ 2,800
660 @ 1,500
Six-speed manual
Cummins Diesel
370 @ 2,800
800 @ 1,600
Nice Link !!!!
2010 6.7 cummins 4x4 crew cab short bed 6 speed auto 4:10 gears stock for now. Draw tite brake controller
HLC2239CUMMINS is offline
post #4 of 16 (permalink) Old 12-06-2012, 07:16 PM
ADMIN/MAFIA
neeltburn's Avatar
Moved to the New 2013+ section. Feel free to post the info you guys find here in this section!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 16 (permalink) Old 12-07-2012, 04:09 AM Thread Starter
Here are some links with information about the 2013 HD pickups.
Powertrain changes: http://blogs.cars.com/files/2013_ram_hd_powertrain.pdf
Engineering changes: http://blogs.cars.com/files/2013_ram_hd_engineering.pdf
2013 Design changes: http://blogs.cars.com/files/2013_ram_hd_design.pdf
2013 Safety & security changes: http://blogs.cars.com/files/2013_ram...security-1.pdf
singles club # 198
post #6 of 16 (permalink) Old 04-10-2013, 12:27 AM Thread Starter
Today while at the dealer getting my oil changed, I looked at the 2013's on the lot. They looked very nice, much better then my 07, just waiting to pull the plug on a new one.
Wanted to see if I could tell how they increased the RA capacity by 200 lbs... They increased the rear tire pressure to 75 psi from 70 in the prior years. Why they didn't go to a full 80 and give a full 6390 that the tires are rated for except to give it to the 3500 srw trucks. Also the rear spring they are going with a 3 leaf main pack instead of a 4 leaf pack on the 2012 and earlier models. Also it looked like the overload lower leaf is a bit thicker on the 2013 but didn't have a way to measure.
Who has any experience with the Capless fueling system? The 13 has no filler cap for the diesel, just a spring loaded flap inside the fill tube. I see contamination issues. The fuel door on the body has a thin seal that is supposed to seal dirt and water from getting into the capless system. Any one who works/drives in dusty conditions will understand how dust seems to find its way inside. Also I can see water getting in, especially if using a pressure washer to wash and blowing water into the filler area. IMHO, I imagine the seal on the door will have to be watched and replaced when it starts to leak.
If and when I get one the first thing I will do is get some kind of a cap to cover the fill tube opening so water and dirt don't get inside the fill tube and on the flapper. Otherwise I think the capless system is just asking for dirt/moisture getting into the fuel
singles club # 198
post #7 of 16 (permalink) Old 04-10-2013, 12:53 AM
Weld engineer's Avatar
It will be easy to pick out the Dodge guy in the convenience store .
112.56 on Diesel pump #3
Pack of Marlboros
3 pack of Trojan "dust covers".
Wes
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
The Following User Says Thank You to Weld engineer For this addition to TDG:
Dodgefarmer (04-10-2013)
post #8 of 16 (permalink) Old 04-10-2013, 03:04 AM
Benefits of capless fill necks obviously for gassers currently using the technology.
I rented a Ford car once with one.
-Less chance for gas smell on your hands. You simply flip open the fuel door and stick the pump nozzle in. Not having a twist-on/off cap is one less contact with a gasoline-vapor odor source.
-No worries about paint scratching from the dangling gas cap, which manages never, ever to fit properly into whatever holder or restraint the automaker provides to keep it out of the way during fueling.
-No embarrassing cap-dangle thatís a result of driving off in a hurry and forgetting to put the cap back on.
-Minimal chance of bad guys siphoning out your $4 gas. Capless systems use various mechanisms in the fuel-filler neck that make it nearly impossible to stuff in a garden hose and drain a victimís tank.
-No more discomfort for people with arthritis or other impairments that make the act of twisting a cap awkward or painful.
post #9 of 16 (permalink) Old 04-10-2013, 04:47 AM Thread Starter
Wes,
Your points are all legit, but I still prefer to keep the dust and moisture out of the fuel tank. Just looking at the seal on the door I find it hard to believe it will keep the junk out the fuel tube over time. At times during the year the dust is all around and it will find its way to places you don't want it, I even have to resort to blowing the dust out of my cab with the air hose. I have fuel filters and water seperators on my bulk tanks to filter it before it gets pumped and I can easily get triple the life of fuel filters in vehicles and equipment then the manufacture recommends. Maybe when I get older and get arthitis I'll appreciate the capless system.
singles club # 198
post #10 of 16 (permalink) Old 04-10-2013, 12:01 PM
Your disadvantages are valid for sure. I snagged those from an manufacturer website. Of course they didn't note any disadvantages.
Another possoble disadvantage would be whether it accepts the larger fuel nozzle at a big truck pump.
2013 EPA regs slam reefer 0/0's Rogerstar1 Medium and Heavy Duty 1 09-26-2012 02:31 AM
?? 2013 Ford F-Series Hybrids ?? HARLEY6LF250SDU 2011+ 6.7L Power Stroke Diesel 16 10-12-2011 08:51 PM
