2013 Tow Ratings - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 9 replies and been viewed 3507 times.
post #1 of 10 (permalink) Old 01-10-2013, 12:55 AM Thread Starter
Dodgefarmer's Avatar
2013 Tow Ratings
2013 HD tow ratings were just released. Beats Ford and GM. Of course they might be sitting back to wait and see before revising and releasing their numbers.
3500: Tow up to 30,000 lbs and GCWR up to 37,600 lbs.
2500: Tow up to 18,350 lbs and GCWR up to 25,000 lbs.
Her is a link with info: http://www.allpar.com/news/index.php...rd-tow-ratings
singles club # 198
Dodgefarmer is offline
post #2 of 10 (permalink) Old 01-25-2013, 01:59 AM
I read the new engine will have a aluminum head. Is this correct?
chevman
chevman is offline
post #3 of 10 (permalink) Old 01-25-2013, 03:49 AM Thread Starter
chevman
I haven't seen or heard that.
singles club # 198
post #4 of 10 (permalink) Old 01-25-2013, 04:02 AM
This summer when all the new ratings are out, someone should arrange for one of each do a test drive, I would like to see them start at Seattle, run up I 90 to Butte Montana, up to Canada on I 15 to Lethbridge, then down the #3 to Rock Creek down the #33 to Kelowna up the 97C to Merritt, down the #5 to the 264th exit south across the boarder back to Seattle. Load them with the full weight they say they can handle. Full of fuel at Seattle and run 12 hours, pack a lunch, just like a customer would use their truck. none of that sissy BS 7% grade to test for a few miles. This way if they fail, a buyer would know. I live in Rock Creek, beer is in the fridge, and a weigh scale is at Midway, Free!
I do like the look of the Goose neck mount.
Doing this wrought would prove they have a truck that can do the JOB, not some numbers pulled out of their butt.
Johnp3 is offline
post #5 of 10 (permalink) Old 02-08-2013, 11:50 PM
The story telling about the new engine told all 3 have the alumiumn heads or a head for the cummins.
chevman
chevman is offline
post #6 of 10 (permalink) Old 02-09-2013, 12:57 AM
Weld engineer's Avatar
I keep seeing Dodge dually's with Cummins around the Detroit area with m plates (manufacturer) but they have Roush on the door. Many times there are 3 cruising the highway together so something is going on. Fun part of living in MI is seeing the occasional camouflaged new vehicle being driven on the highways or manufacturers testing vehicles.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #7 of 10 (permalink) Old 02-26-2013, 02:52 PM Thread Starter
Its a 2013.5
Here is a link to Cummins TurboDiesel News letter on the new Cummins engine that the are calling a 2013.5 model year. I guess they like thye XXXX.5 mid year changes like the 07.5, and a few others.
http://turbodiesel.cumminsnewsletters.com/
The link has info on HP/Torque ratings for various models and transmission options.
singles club # 198
post #8 of 10 (permalink) Old 03-08-2013, 03:41 AM
new 3500 rams are having frame problems and have not towed anything at this time. Not a good thing for rv'rs.
chevman
chevman is offline
post #9 of 10 (permalink) Old 03-08-2013, 05:10 AM Thread Starter
chevman
What kind of problems have you heard about?
singles club # 198
post #10 of 10 (permalink) Old 03-10-2013, 05:34 AM
ADMIN/MAFIA
neeltburn's Avatar
No 3500 DRW have left the plant. Ram is aware of a problem that came up when the first 10 DRW were built and is correcting an issue with the frame. Ram has also said this problem will not and does not effect the 2500s and 3500 SRWs. just a minor speed bump and was caught in house.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
2013 Ram Dodgefarmer 2013+ 6.7L Cummins HO 15 09-18-2013 02:55 AM
Get Your 2013 Membership before Jan. 31st and get a FREE 2013 Calendar! NHRDA NHRDA 0 01-03-2013 11:58 PM
?? 2013 Ford F-Series Hybrids ?? HARLEY6LF250SDU 2011+ 6.7L Power Stroke Diesel 16 10-12-2011 08:51 PM
SAE sets standards for Tow ratings!!! John_G Towing and Hauling 2 07-24-2011 05:18 PM
