DIESEL ADDITIVES - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stillcummin, this thread has received 10 replies and been viewed 3364 times.
post #1 of 11 (permalink) Old 11-26-2013, 02:21 PM Thread Starter
stillcummin's Avatar
DIESEL ADDITIVES
Ok ive got a new 13 will it hurt to run fuel additive or is it best not to I always ran howes in my 07 5.9, thanks for any help on this
BLACK 2013 RAM 3500HD BIGHORN EDTION
385hp/850tq AISIN TRANS, ALCOA WHEELS,ROUGH COUNTRY 2.5'' LEVELING KIT, WHEEL TO WHEEL STEPS,B&W TURN OVER BALL,DURAFLAP MUD FLAPS,TINTEDWINDOWS,RIDE RITE AIRBAGS,BIG TEX GRILLEGUARD, I'M SURE THERE WILL ALOT MORE TO COME SOONER OR LATER
stillcummin is offline
post #2 of 11 (permalink) Old 11-26-2013, 02:51 PM
Aimless Wanderer
Howes is good stuff. Run it, (IMO).
The question I seek an answer for is simply; why, or why not?
Backslap is offline
The Following User Says Thank You to Backslap For this addition to TDG:
stillcummin (11-26-2013)
post #3 of 11 (permalink) Old 11-26-2013, 05:57 PM
Unless you are running a long ways north you do not need any aditives I have a 2007 Duramax, I did put in one aditive to try it, It was suppose to clean the fuel system. I put it in a full tank of fuel and change the filter in the fall when it was at 1/4 never found anything special in the filter.
If you remember Prolong, and every aditive package from speedway corporation they were found to be 100% BS. They are still sold.
Cat use to have a decal on all their equipment, it said buy clean fuel and keep it clean, never once did I ever go to an engine course and they said to use an aditive, never once saw an aditive fix a problem, and never once had a customer come in with a fuel problem say he put in an aditive.
Just a thought!
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
post #4 of 11 (permalink) Old 11-26-2013, 11:04 PM
One other thing many additives have ingredients allowing the water to bypass the filter. That water when it gets to the injector/fuel nozzle will do damage.
If you read a lot of threads about additives and injector problems, they do seem to go together, I work on a 7.3 it has 300,000 plus miles on it, was smoking and hard to start we changed the valve cover gaskets, and the glow plugs, problem solved he never used any additives.
Just a thought!
Johnp3 is offline
post #5 of 11 (permalink) Old 11-26-2013, 11:16 PM
Weld engineer's Avatar
Archoil 6200
http://www.archoil.com/index.cfm/pro...-mass-balance/
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #6 of 11 (permalink) Old 11-27-2013, 03:25 AM
Dodgefarmer's Avatar
I run Stanadyne Performance additive once in awhile in my 2013. Ran it also in the 07.5 I had. In that truck noticed about a 0.5 mpg increase and better throttle response. So far in the 13 havn't noticed the same difference, although only have 6,000 miles on it so far. I run it mostly for the extra lube.
singles club # 198
Dodgefarmer is offline
post #7 of 11 (permalink) Old 11-28-2013, 02:26 PM
ADMIN/MAFIA
neeltburn's Avatar
I run Howes in the Winter with my 12 and Power Service Diesel Kleen in the summer. Works fine.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
stillcummin (11-28-2013)
post #8 of 11 (permalink) Old 12-08-2013, 10:34 PM Thread Starter
We had a class on dpf and urea for jd tractors at one time they said to put additives in fuel and in the same breath they said not to that would make more particulate matter so knows
post #9 of 11 (permalink) Old 12-12-2013, 03:33 AM
ADMIN/MAFIA
neeltburn's Avatar
Howes states on the bottle DPF safe!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 11 (permalink) Old 12-12-2013, 06:44 PM
I worked at a truck dealership, we use to service a fleet of trucks that hauled chips over the chockahalla, 144.000 lbs, over two mountains, they tried every aditive there ever was, and kept records on every truck, they could tell you how much it cost per mile on every single part on the trucks as a fleet and as a single unit, what every driver, cost above or below average in fuel costs, and the only aditive they ever found that did anything was Nal-cool. One driver after picking up a tank of fuel with water in it, when he got to Westbank he put in a load of methyl-hydrate, instead of just draining and changing the fuel filters he had on board because he would have to lift the cab, it was a cab over, it cost them a set of injectors in about a week they knew there was a problem, the milage went to hell.
I do believe I have seen every one of the latest and greatest, from the additives by Speedway Corporation like Prolong, to the adding Cow magnets in the fuel tank to attaching them around the fuel lines.
I can understand using a Biocide, and an anti-gel if going north, the rest are 100% BS, you would do better to put a coil of crap on the back of your truck expecting the smell to push you.
Any time anyone swears they got an increase in mileage, well, that would have to mean they got an increase in power, well lets see them put it on the dyno for say 5 minutes, at a high power level, lock the throttle then put in the aditive, let it run for 1/2 an hour the speed should increase, if it does not then it is BS. Has anyone ever seen this done if not then they know there aditive is BS.
If you disagree, put your truck on the dyno, and prove it.
Just a thought!
Johnp3 is offline
Diesel additives : your .02 ? Diesel Brad General Diesel 5 07-30-2011 04:13 PM
Diesel Additives? tjigger The Polling Place 25 05-02-2008 01:41 PM
Diesel Additives required? BCMC 6.7L Cummins (2007.5-2011) 10 01-25-2008 04:04 AM
Diesel Fuel additives seapig 2008-2010 6.4L Power Stroke 13 01-23-2008 10:15 AM
diesel additives for cold weather... rocweiller 2003-2007 6.0L Power Stroke 13 12-05-2006 01:28 PM
