SPRAY IN BEDLINER - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stillcummin, this thread has received 11 replies and been viewed 3026 times.
post #1 of 12 (permalink) Old 12-01-2013, 10:50 PM Thread Starter
stillcummin's Avatar
SPRAY IN BEDLINER
What is your guys thoughts on spray in liners never had it done to any of my trucks in past, I work at John Deere we just got a new service truck and they had it done to it and it looks really good the liner is armor thane said they would do my truck for 400 just not sure if its worth it or not
BLACK 2013 RAM 3500HD BIGHORN EDTION
385hp/850tq AISIN TRANS, ALCOA WHEELS,ROUGH COUNTRY 2.5'' LEVELING KIT, WHEEL TO WHEEL STEPS,B&W TURN OVER BALL,DURAFLAP MUD FLAPS,TINTEDWINDOWS,RIDE RITE AIRBAGS,BIG TEX GRILLEGUARD, I'M SURE THERE WILL ALOT MORE TO COME SOONER OR LATER
stillcummin is offline
post #2 of 12 (permalink) Old 12-02-2013, 12:35 AM
Dodgefarmer's Avatar
I had always used rubber mats in the past until I got the 2013 that had the factory spray in liner. Don't know what brand the liner is though. So far its been better against things wanting to slide in the bed. The factory liner seems to be a bit tacky, almost a rubbery feel compared to other liners I had seen which seem to helps against sliding. That being said, I like it since it also protects the inner sides of the bed and tailgate that the rubber mat did not. Thats my .02 cents worth
singles club # 198
Dodgefarmer is offline
stillcummin (12-02-2013)
post #3 of 12 (permalink) Old 12-02-2013, 12:38 AM
Aimless Wanderer
It won't stop the rust and makes it a real SOB to repair should you need a bedside installed down the road. They are great at making things quieter that are in the bed for certain and do a fair job of keeping things from sliding. This same thing is accomplished with a rubber mat and rubber cement around the rear of the mat for a whole lot less money. The vendors hawk improved resale value of which I've never seen attained. Not saying they're a bad idea, I just don't see the great benefit advertised.
The question I seek an answer for is simply; why, or why not?
Backslap is offline
The Following User Says Thank You to Backslap For this addition to TDG:
post #4 of 12 (permalink) Old 12-08-2013, 02:05 AM
ADMIN/MAFIA
neeltburn's Avatar
Here is the Line-x in my 12 really happy with it!.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #5 of 12 (permalink) Old 12-08-2013, 02:56 AM
Aimless Wanderer
Looks like you only use the bed to walk to the toolbox. Guess the "Line-X" will keep you from slipping.......
I plated the floor of my Dodge with 1/4" aluminum cause you could see every xmember in the floor from using the truck as it was meant to be carrying pallets of automotive cores for rebuild.
Backslap is offline
post #6 of 12 (permalink) Old 12-08-2013, 02:38 PM
ADMIN/MAFIA
neeltburn's Avatar
Picture was taken after I got the B&W installed.. other than being dirty it looks the same a year later! Its had a Companion Hitch sitting on it, and had steel targets dropped on it. (AR500)
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 12 (permalink) Old 12-08-2013, 07:12 PM
Line-X. I haul dirt home wash it out and looks like new. Well worth the money!
skirk55 is offline
The Following User Says Thank You to skirk55 For this addition to TDG:
jasoneads (03-18-2014)
post #8 of 12 (permalink) Old 12-08-2013, 10:27 PM Thread Starter
well went ahead and got the armor thane like we put in company truck they said it was a military grade stuff looks good ill get some pics up soon, thanks for all the input
post #9 of 12 (permalink) Old 03-18-2014, 02:49 PM
I agree 100%! When I bought my truck it already had the bedliner sprayer with Line-x. It holds up to everything I do with putting engine blocks and everything else in it. Line-x is the way to go!
jasoneads is offline
post #10 of 12 (permalink) Old 03-18-2014, 06:55 PM
I have linex, and have had two pallets slid in a few times and there is no damage one was pellets, 2,000 lbs, the other was bricks, I do not know the weight I was in town and a friend was getting loaded up and we found a broken spring so I agreed to take it home for him. I know it was heavy.
I haul mostly wood in the box, on pallets and i pull it out with a chain, or fire wood. no marks. I would definitely do it again if I buy a new one.
Just a thought!
Johnp3 is offline
Which spray in liner? neeltburn The Parking Lot 13 01-11-2011 04:36 PM
What do you guys use to clean your spray in bedliner? LIVIN General Ford Truck and Excursion 17 06-16-2009 05:30 AM
in and out detail spray POWER STROKE 99 The Detailing, Paint & Bodyshop 0 03-07-2008 12:00 AM
Spray in bedliner ?'s 01blkf250 General Ford Truck and Excursion 6 07-12-2007 03:02 PM
Rhino / LineX quotes, to spray or not to spray that is the question Shadowskater General Ford Truck and Excursion 5 07-10-2007 06:04 PM
