2013 Ram 3500 Vibration - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by task125, this thread has received 2 replies and been viewed 3439 times.
post #1 of 3 (permalink) Old 02-17-2014, 10:58 PM Thread Starter
task125's Avatar
I have a ram 3500 4x4 Drw with a vibration at around 70mph
does not shake in the steering wheel thinking its something in the rear.
Tires where all roadforce balanced drive shaft replaced and was told a rear hub was loose.still vibrates.
13 Ram 3500 DRW 4x4 Aisin Longhorn Mega
09 Polaris 850XP
1957 Willys cj5
2006 International CXT
IAFF 305
task125 is offline
post #2 of 3 (permalink) Old 02-18-2014, 12:26 AM
A bad shock will do that, after a trip just feel them if they are warm then they are good if cold they are junk.
Jack up the wheels and spin them see if a trie is out of round, I take it you had the wheel hub tightened up? Look at the brake rotors and see if one is cracked or if drums, look for a weight missing. Even with the drive shaft balanced is it Phased corectly?
If everything looks good put it on a set of stands, and run it up gently. or if you can get someone to drive it and you look from the back or at each side.
Just a thought
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
task125 (02-19-2014)
post #3 of 3 (permalink) Old 02-20-2014, 04:45 PM Thread Starter
task125's Avatar
Just put 1800lbs in bed and vibration is worse.. even feel it at 35 now. its a stronger feeling now
09 Polaris 850XP
1957 Willys cj5
IAFF 305
task125 is offline
2013 Ram Dodgefarmer 2013+ 6.7L Cummins HO 15 09-18-2013 01:55 AM
2013 Dodge Ram Cummins Amsoil Diesel Oil jeffh27 General Dodge Discussion 1 05-17-2013 02:04 AM
Get Your 2013 Membership before Jan. 31st and get a FREE 2013 Calendar! NHRDA NHRDA 0 01-03-2013 10:58 PM
01 ram 3500 92cummins Whats Been Sold 16 06-03-2007 05:51 PM
