6 speed manual 600lbs torque< aisin 6 speed auto - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fluxcore8, this thread has received 3 replies and been viewed 1625 times.
post #1 of 4 (permalink) Old 03-19-2015, 07:25 PM Thread Starter
why can a geared tranny put out as muck as a aisin 6 speed auto trans with 885 lbs torque thanks
fluxcore8 is offline
post #2 of 4 (permalink) Old 03-19-2015, 08:23 PM
Dodgefarmer's Avatar
Originally Posted by fluxcore8 View Post
why cann't a geared tranny put out as muck as a aisin 6 speed auto trans with 885 lbs torque thanks
I assume you mean "can't"
The clutch won't handle the torque very long, it will start slipping. Also it has to due with the strength of the transmission gears and shafts, to much torque/twisting will lead to breakage unless you know how to drive it.
singles club # 198
Dodgefarmer is offline
post #3 of 4 (permalink) Old 03-20-2015, 03:24 PM Thread Starter
i ment geared transmission should put out almost 100 %.
post #4 of 4 (permalink) Old 03-20-2015, 06:01 PM
The engine is "detuned" to a lower torque/Hp. with the manual transmission.
singles club # 198
fluxcore8 (03-20-2015)
6.0 with a 6 speed manual? goblues39 2003-2007 6.0L Power Stroke 5 11-22-2010 12:33 PM
6 speed manual shifting? ehopp88ss 5.9L Cummins (2003-2007.5) 23 03-13-2010 12:07 AM
switching from a manual 5 speed to a manual 6 speed BEHR2010 1994-2003 7.3L Power Stroke 13 04-25-2009 03:27 PM
6-speed Auto Aisin or NOT? Dodge/Cummins Lies kenji69 6.7L Cummins (2007.5-2011) 66 01-17-2008 11:58 PM
Torque shift or 6 speed Diesel Fanatic 1994-2003 7.3L Power Stroke 7 01-04-2008 10:13 PM
