Ford F-250 / F-350 Cargo Light LEDs! See Comparison Photos & Install Video! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diode Dynamics, this thread has received 4 replies and been viewed 689 times.
post #1 of 5 (permalink) Old 05-02-2016, 07:03 PM Thread Starter
Diode Dynamics's Avatar
Arrow Ford F-250 / F-350 Cargo Light LEDs! See Comparison Photos & Install Video!
Ford F-250 / F-350 Super-Duty Cargo Light LED
http://www.youtube.com/watch?v=5HVZvfbDFh4
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your Ford F-250/F-350's cargo light bulb (921 size). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two 921-sized LED bulb replacement, for perfect fitment in all Ford F-250 / F-350 Models.
Bulb Design
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
Fitment. All three bulbs use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for cargo lights. Just replace the factory bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP5: Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology. (92 lumens)
HP36: Slightly higher brightness than OEM bulbs. (210 lumens)
XP50: Much brighter than OEM bulbs. These are bright! (410 lumens)
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 5 (permalink) Old 05-03-2016, 01:31 PM Thread Starter
post #3 of 5 (permalink) Old 05-22-2017, 08:34 PM Thread Starter
Here's an output shot with our red HP5 LED replacement in the third brake light location!
Nick C.
post #4 of 5 (permalink) Old 07-03-2019, 09:06 PM Thread Starter
JULY 4TH SALE! 20% OFF ALL DIODE DYNAMICS PRODUCTS!
Don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
post #5 of 5 (permalink) Old 07-05-2019, 09:25 PM Thread Starter
Jake H.
Diode Dynamics
Ford Super Duty Fog Light LED Bulbs! See Comparison Photos! & Install Video Diode Dynamics Diode Dynamics 12 05-29-2020 07:41 PM
Chevrolet Silverado License Plate LEDs! Install Video! Same-day Shipping! Diode Dynamics Diode Dynamics 6 05-21-2020 09:20 PM
2015 Ford F-350 Super-Duty in the Studio for Comparison Shots & Install Videos! Diode Dynamics Diode Dynamics 0 05-02-2016 04:06 PM
98 E-350 7.3 cargo van Diesel Dave 04 Vehicles For Sale 1 11-07-2012 06:06 PM
Blue Ford Topper 8' F-250/350 99+ BenBone Ford Parts 0 05-05-2010 04:02 PM
