Help with SMARTY ME 2007.5 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by your nightmare, this thread has received 13 replies and been viewed 1167 times.
post #1 of 14 (permalink) Old 07-09-2010, 02:03 AM Thread Starter
Redneck with some Bling
your nightmare's Avatar
Images: 1
Ok here is what mods I have
6.7l fire rings
new bigger valve seets
Ported head
grid heater delete
pro gate exhaust waste gate
FASS 150
stacks
banks cold air intake w/super scoop
It says to unplug the TPS and leave the EGR dump valve ontop hooked up and to disconect the EGR valve on the exhaust system
What happens if the TPS is left hooked up for 3+k miles???????
has anyone done it before
I have my reasons for asking these questions and I will post them later but I whant to hear what you all think
Thanks
2007 Dodge 2500 Mega cab Laramie fully loaded (love my heated seats in the winter) 6.7L
Banks cold air intake w/super scoop techni-cooler
wishing someone would steal my DPF Holly crap it fell off the other day
EGR stealth kit on
SMARTY OMG love it
6" stacks
Klienn Train horns 156.9db Get out of my way or you will pee yourself
HID projector headlights Custom grill with 7" EURO lights ("can you see me now")
37x14.5x20 NITTO TG HELO rims
6" TGC W/ pure porformance long arm kit
6" ATLAS rear springs
Rides like a 1500
to all military members MARINE
http://www.youtube.com/watch?v=9jYwzk-G4Q8
http://www.youtube.com/watch?v=Dx3Qkjljk4o
your nightmare is offline
post #2 of 14 (permalink) Old 07-09-2010, 03:31 AM
ADMIN/MAFIA
neeltburn's Avatar
6.7l fire rings
Ported head
grid heater delete
FASS 150
stacks
Thanks
TPS?
Here are the EGR Delete institutions for ME software.
Unplug Servo on EGR Cooler
take the screw and Spring out of the EGR Motor on the top of the intake.
Unplug the Butterfly in the intake horn.
By TPS do you mean Throttle Position Sensor? Are these the Instructions you are going by?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 14 (permalink) Old 07-09-2010, 04:46 AM Thread Starter
Images: 1
Originally Posted by neeltburn View Post
TPS?
Yes Neel tps Throttle Position Sensor
I had my truck worked on and they pluged it back in and now I have some issues and I will leave it at that may not be the problem but I need some input
EGR stealth kit on
SMARTY OMG love it
6" stacks
Rides like a 1500
post #4 of 14 (permalink) Old 07-09-2010, 04:56 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Does smarty require you to have the TPS unplugged? Im kinda confused as to why it was unplugged in the first place. What did they work on?
Military Quote Of The Year
SOOTBANDIT is offline
post #5 of 14 (permalink) Old 07-09-2010, 04:57 AM
ADMIN/MAFIA
neeltburn's Avatar
Ok any codes check with smarty and by key?
Symptoms?
Id imagine that you had a CEL with it unplugged right? Can you explain you issues they might help. sorry man Im fishing....but you can PM me if you would like to keep it on the down low.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 14 (permalink) Old 07-09-2010, 04:57 AM
ADMIN/MAFIA
neeltburn's Avatar
NOPE
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 14 (permalink) Old 07-09-2010, 05:03 AM Thread Starter
Images: 1
I just looked at it and it says that it must be unpluged and no CEL pluged or unpluged
My problem is going to set me back $6000-$7800
EGR stealth kit on
SMARTY OMG love it
6" stacks
Rides like a 1500
post #8 of 14 (permalink) Old 07-09-2010, 05:07 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
What is going to cost you $6000 to 7800? What is the truck doing not running etc...
post #9 of 14 (permalink) Old 07-09-2010, 05:07 AM
ADMIN/MAFIA
neeltburn's Avatar
Do you have the EGR cooler on it?
Where is this TPS located?
I have never heard about having to unplug a TPS. If it is the Throttle postilion sensor I can't understand how the truck would run?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 14 (permalink) Old 07-09-2010, 05:19 AM Thread Starter
Images: 1
Sorry Correct tem is "throttle valve"
Brandon I lost 5th and 6th gear in my trany and 4th is slipping
EGR stealth kit on
SMARTY OMG love it
6" stacks
Rides like a 1500
2007.5 6.7 Quantum 6.7L Cummins (2007.5-2011) 9 04-08-2010 03:04 AM
2007.5+ kenji69 Duramax 07.5-2010 (LMM) 0 12-13-2007 08:57 PM
2007 Job #1 vs Job #2 ? jmcholden 2003-2007 6.0L Power Stroke 4 10-15-2006 08:14 PM
2007 Sd jdelongmotorsports 2003-2007 6.0L Power Stroke 3 06-15-2006 05:09 AM
2007 and Beyond Pourinthecoal 2003-2007 6.0L Power Stroke 22 09-17-2005 03:15 PM
