Looking for the bed T-pipe for a 6'' stack kit. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3FordPower, this thread has received 4 replies and been viewed 599 times.
post #1 of 5 (permalink) Old 10-18-2010, 10:34 PM Thread Starter
7.3FordPower's Avatar
I just bought a set of 6'' Aussie stacks off of a friend and am looking for the bed piping to install them. I need all clamps and brackets also. Thanks Austin.
96 F250 regular cab long bed 4x4, 176,000, 4inch exhaust with 6''x24'' tip, Gauges (boost, pyro, tranny temp) DIY intake, Dp-tuner F5 (80echo, 120hp, 140hp, 60 tow, lope idle) 33x12.5 BFG AT's on eagle rims with a front leveling kit. And to many lights on it.
7.3FordPower is offline
post #2 of 5 (permalink) Old 10-18-2010, 11:18 PM
http://www.dfuser.com/catalog/grandrock_stacks.php
This should help
dfuser is offline
post #3 of 5 (permalink) Old 10-19-2010, 08:34 PM
KT Performance's Avatar
Are the stacks reduced to 5" at the bottom? Is the inlet ID (measurement of inside of the pipe) or OD (measurement of outside of the pipe)?
Kenny
352-636-0812
KT Performance is offline
post #4 of 5 (permalink) Old 10-19-2010, 11:47 PM Thread Starter
they reduce down to five.
post #5 of 5 (permalink) Old 10-20-2010, 11:29 AM
DO you happen to know what brand the stack are... or more importantly, if they are ID (expanded side) 5" or OD (goes inside of the expanded pipe) 5"?
It will determine what kit will work with the stacks you have.
Thanks,
Kenny
352-636-0812
Single stack OR 36 in. piece of 6 in pipe Jeffybuilt Dodge parts wanted 3 10-15-2009 07:57 PM
pipe it or stack it..... blackcloudCTD95 The Polling Place 9 01-17-2009 09:13 PM
stack pipe on cab of international? mrod67 Medium and Heavy Duty 1 11-14-2007 03:18 PM
One stack/pipe Big Gray dodge 5.9L Cummins 12 Valve (1994-1998.5) 7 06-14-2007 04:57 AM
New Custom Y-Pipe Covers for Stack Kits 95psdF250 Supporting Vendors Forum 10 09-13-2006 12:27 PM
