OVER 20% OFF 12V Cummins MLS Exh Manifold Gaskets !!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JacktheBear3, this thread has received 0 replies and been viewed 1321 times.
post #1 of 1 (permalink) Old 09-13-2011, 02:53 AM Thread Starter
JacktheBear3's Avatar
SAVE $12.00 On Industry Best, MLS (multi layer stainless steel) Exhaust Manifold Gaskets
Until the end of September..... save over 20% on Exhaust manifold gaskets for our 12V Cummins.
Use coupon code at check out and get $12.00 off
These gaskets are a proven winner, improved seal, ease of install, gotta have them...
If your not aware of what they are... Read here Keep in mind that the gaskets we are discounting are 12V with square ports.... the image on this thread are 24V gaskets.
New style gasket, using the latest MLS (Multi Layered Steel) technology has some neat features that might just fit your project. Buying a 3-piece manifold has become the norm, and that means intalling new gaskets. If you've ever struggled installing 6 individual steel gaskets, fiddling with the bolts and manifold trying to line everything up... then this new style gasket is just for you.
  • MLS 3-Layer Design (great for 3 piece manifold movement)
  • High Quality Stainless Steel Construction
  • "Banked" Design, Simple Installation, only two pieces to put into place
  • Slotted Bottom Holes: Insert a few mounting bolts and Slide the gasket behind the manifold for easy completion of install
  • .040" Thickness
  • Re-Usable
  • Affordable: Compared to other options out there.
The above picture is the 24V ISB and CR version, 12Valve 2nd Gen gaskets have slightly different port dimensions for use with oem manifolds.
Discount Code MLS12V
Enter it at check out and get +20.00% off for the entire month of September!
JacktheBear3 is offline
Exhaust Manifold Gaskets Old Big and Slow 1994-2003 7.3L Power Stroke 2 08-25-2011 01:39 AM
exhaust manifold gaskets needed! SSpeeDEMONSS Supporting Vendors Forum 4 09-03-2009 09:40 PM
vt-785 cummins gaskets tegbert Whats Been Sold 0 02-11-2009 06:39 PM
Cummins gaskets Macktruckdriver 5.9L Cummins 12 Valve (1994-1998.5) 12 03-16-2008 05:02 PM
Can exhaust manifold gaskets be reused??? steved 5.9L Cummins (2003-2007.5) 2 07-20-2007 02:59 AM
