f150 EXHAUST - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wftree, this thread has received 5 replies and been viewed 524 times.
post #1 of 6 (permalink) Old 04-07-2006, 02:16 PM Thread Starter
what does not kill you ..
f150 EXHAUST
My company truck is a Gasser 2002 F150 5.4 super cab short bed
I just developed an exhaust leak. I may be needing an exhaust system. Any of the vendors carry stuff for little trucks
wftree
1999.5 F450 CC 4x4 315HP/709tq 6 speed with BD short shifter; DP chip: stock, , high idle, 40tow, 80econo, 80 tow, 100, 140,South Bend clutch; ported BB turbo; SPEARCO 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; HX hose; shimmed regulator; Tymar intake; zoodad; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; Dahl 100 heated fuel filter; in tank/pre pump mod, Hella FF driving & fog lights, Ford of Ocala SUCKS!
WORK TRUCKS '90 F450 7.3 flat bed, '90 Inter 7.3 flatbed, '96 F450 7.3 dump, '96 F800 5.9 Dump, '00 FL60 Cat Lift truck, '02 F150 5.4 pickup, '04 F550 6.0 Dump, '04 f350 6.0 pickup, '07 F550 6.0 Flatbed, '04 f450 dump
wftree is offline
post #2 of 6 (permalink) Old 04-07-2006, 03:04 PM
There are many options for your from single side/rear exhaust, dual side/rear, aluminum, stainless...You name it. There are also some 5 manufacturers to choose from.
dfuser is offline
post #3 of 6 (permalink) Old 04-07-2006, 03:14 PM
I highly recommend Magnaflow, I had one on my 99 f150 and thought it was a great system.
I love the sound and the fit is excellent
nummit is offline
post #4 of 6 (permalink) Old 04-07-2006, 03:23 PM
Supporting Vendor
SeeYa's Avatar
Images: 1
I have a mag coming off my 2002 f150 hd super crew. You might have to make some adjustments to accomodate your super cab. Check out the magnaflow webiste and see. If interested please PM me.
SeeYa is offline
post #5 of 6 (permalink) Old 04-11-2006, 05:55 PM
wftree,
Give us a call we have all the MBRP gas system that'll work for you!
Mark @ DPPI
Mark_Craig is offline
post #6 of 6 (permalink) Old 04-12-2006, 01:27 PM Thread Starter
Finally got the chance to look for the leak. IT IS THE MANIFOLD.
SOB
Of course this has to happen during my busy season, All winter I would have had the time to fix it. I might end up taking it to a shop.
WFTREE
wftree is offline
