Direct Injection Performance coolant filter - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by onebadf150, this thread has received 7 replies and been viewed 494 times.
post #1 of 8 (permalink) Old 04-16-2006, 01:05 AM Thread Starter
TDG MAFIA MEMBER #85
onebadf150's Avatar
I'm New to the whole diesel world so bare with me, but what is the reason for adding a coolant filter? I'm sure it has a good purpose so can you please explain?
Thanks Everyone :Thumbup:
Nick
onebadf150 is offline
post #2 of 8 (permalink) Old 04-16-2006, 01:35 AM
4cstr
When the block was cast and flushed...some of the casting sand particles were left in the coolant passageways. These particles eventually wear on the water pump. The filter gets 'em outa there.
Some have reported having their filter plug within 3 months of putting it on from all the casting sand left in the block.
post #3 of 8 (permalink) Old 04-16-2006, 02:06 AM Thread Starter
onebadf150's Avatar
Thanks 4cstr, for the quick reply and info
post #4 of 8 (permalink) Old 04-16-2006, 04:46 AM
TDG Mafia Member #24
The flow on mine was down to almost nothing in 5000 miles. Well worth the money in my opinion.
:grd
"Can You Keep Up?"
AUGSX is offline
post #5 of 8 (permalink) Old 04-18-2006, 09:25 PM
Kermit's coolant system is nice and it works with the bigger bank's intercooler tube and it's easier to change and the hoses are good quality...I would reccomend his set up....
j.schall
jschall is offline
post #6 of 8 (permalink) Old 04-18-2006, 09:29 PM
you are suppose to flush your coolant system at 100k miles but buy then a lot of the damage is done in my opinion..This is a list of the things your coolant flows through...
egr cooler
radiator
transmission cooler
oil cooler
heater core
lot's of expensive stuff .....the big rigs run them so why shouldn't we..lol..
jschall is offline
post #7 of 8 (permalink) Old 04-18-2006, 10:09 PM
hmmm, I have 225K miles on my original engine, I get it flushed every 100K miles, and I have not had a problem so far. Still on original water pump, thermostat, and Radiator too.
Not saying that the filter is a bad thing though!
dfuser is offline
post #8 of 8 (permalink) Old 04-19-2006, 12:34 AM Thread Starter
onebadf150's Avatar
Good Info I'll deffinitly look into getting one. How often do you change the filter and how do you tell if its clogged with contaminents?
:thanks:
Nick
