New air filters from AMSOIL - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Don Stefanik, this thread has received 5 replies and been viewed 645 times.
post #1 of 6 (permalink) Old 05-04-2006, 02:28 PM Thread Starter
AMSOIL Introduces New Ea Air Induction Filters Featuring Nanofiber Technology for Maximum Engine Performance
Superior, WI -- AMSOIL unveiled today its new line of universal air induction filters, designed to replace stock oil wetted gauze or foam conical filters typically supplied by K&N, Injen, Green, AIRAID, AFE, TrueFlow and more. AMSOIL Ea Air Induction Filters offer superior efficiency, excellent airflow and are cleanable.
Like other filter products in the AMSOIL Ea line, the new filters utilize nanofiber technology and were developed through partnerships with global filtration leaders. The collaborative effort has been orchestrated by AMSOIL with the aim of producing a filter unsurpassed in efficiency and service life. Key benefits of the Ea Air Induction Filters include:
Excellent airflow without compromising filtering efficiency
Superior construction and cleanable design for longer service life
Unique design to increase surface area and air flow volume
AMSOIL Ea Air Induction Filters are available in nine styles with varying lengths and widths with flange IDs of 3, 3.5, 4 and 4.5 for universal fitment. Whereas intake kits were once sold only for performance applications, in recent years they have been marketed and used as a way to boost fuel economy in SUVs, minivans, trucks and more.
More Cold Air = More Horsepower
The basic purpose of the air intake system is to bring cool air from outside the engine compartment into the engine. The cooler air is denser than the air found within the hot engine compartment. The denser charge contains more oxygen than warmer air, providing better combustion through a more effective air/fuel mixture.
Another advantage of most specialty-equipment cold air intakes is their consistent diameters and the absence of sharp bends, both of which help to eliminate turbulence in the air stream.
Large and Growing Market
According to research done by the Specialty Equipment Market Association (SEMA), a new air intake system is among the first modifications a consumer makes to his or her vehicle. Since changing the air filter alone cannot eliminate air restriction built into the vehicle at the factory, replacing the factory air flow assembly includes replacing the filter, air box and air path. SEMA reports sales of air intakes are over 300,000 every year.
While intake kits were initially sold only for performance-type applications, they are now also being marketed and used as a way to boost fuel economy in SUVs, minivans, trucks and more.
AMSOIL EaAU
AMSOIL Ea Air Induction Filters fit most of the popular intake systems available. They provide improved cold air intake and a level of engine protection only an Ea Filter can provide. AMSOIL is currently offering nine Ea Air Induction Filters with varying lengths and widths. These filters have flange IDs of 3", 3.5", 4" and 4.5". Since these filters offer a universal fit, AMSOIL provides the dimension sheet below that customers can use to determine the proper filter for their applications.
Cleanable
AMSOIL Ea Air Induction Filters are cleanable and long lasting. AMSOIL recommends cleaning the Ea Air Induction Filter when designated by the restriction gauge if the vehicle is so equipped, or according to operating conditions. If it is used in extremely dusty environments or in a performance vehicle, more frequent cleanings may be required.
Unique Design
To increase filter surface area and the volume of air entering the engine, the top of the Ea Air Induction Filter is cut away. The media is inserted in a conical form pointing toward the direction of airflow.
Quality Construction
AMSOIL Ea Air Induction Filters are made from the same high-quality nanofiber media found in other AMSOIL Ea Air Filters. The nanofiber media is pleated with epoxy-coated wire on the face and back of the media for additional strength and stiffness. High quality, pliable urethane connectors with plastisol potting complete the product. Each Ea Air Induction Filter comes with a clamp for convenient installation.
AMSOIL# Product Style Flange
Type Base
OD (in) Flange
ID (in) Flange
Length (in) Media
Height (in) Top
OD (in)
EaAU3570 Round Tapered Center 4.625 3.50 0.625 7.0 3.5
EaAU4090 Round Tapered Center 6.000 4.00 1.750 9.0 5.0
EaAU3050 Round Tapered Center 6.000 3.00 1.750 5.0 5.0
EaAU3051 Round Tapered Center 6.000 3.00 1.750 5.0 4.0
EaAU3590 Round Tapered Center 6.000 3.50 1.750 9.0 5.0
EaAU4560 Round Tapered Center 5.875 4.50 0.625 6.0 5.0
EaAU3090 Round Tapered Center 6.000 3.00 1.750 9.0 5.0
EaAU3555 Round Tapered Center 4.625 3.50 0.625 5.5 3.5
EaAU3560 Round Tapered Center 6.000 3.50 1.750 6.0 5.0
Don Stefanik is offline
post #2 of 6 (permalink) Old 05-04-2006, 03:19 PM
4cstr
Don...are these dry filters or do they also need re-oiling after cleaning? Either way...I'm sure they are some good chit coming from Amsoil.
Dave
post #3 of 6 (permalink) Old 05-04-2006, 03:51 PM Thread Starter
These new filters do not use oil. This has become a problem because of the sensors in the newer vehicles. And AMSOIL wanted tthese filters to be user friendly. You can actually vacum them or blow them out. Guarranted for 4 years 100,000 miles.
Take some time and read up on these new filters....you will be impressed.
http://www.amsoil.com/filtration/
post #4 of 6 (permalink) Old 05-08-2006, 05:25 PM
what does not kill you ..
Which one of these would replace the Donaldson in the Tymar
wftree
1999.5 F450 CC 4x4 315HP/709tq 6 speed with BD short shifter; DP chip: stock, , high idle, 40tow, 80econo, 80 tow, 100, 140,South Bend clutch; ported BB turbo; SPEARCO 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; HX hose; shimmed regulator; Tymar intake; zoodad; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; Dahl 100 heated fuel filter; in tank/pre pump mod, Hella FF driving & fog lights, Ford of Ocala SUCKS!
WORK TRUCKS '90 F450 7.3 flat bed, '90 Inter 7.3 flatbed, '96 F450 7.3 dump, '96 F800 5.9 Dump, '00 FL60 Cat Lift truck, '02 F150 5.4 pickup, '04 F550 6.0 Dump, '04 f350 6.0 pickup, '07 F550 6.0 Flatbed, '04 f450 dump
wftree is offline
post #5 of 6 (permalink) Old 05-08-2006, 05:45 PM
Ramprat's Avatar
wftree
Was wondering the same thing, have not cleaned or replaced my TYMAR since installing it 5 or 6 years ago & it's still looking good
Ramprat is offline
post #6 of 6 (permalink) Old 05-10-2006, 03:24 AM
I am too definatley interested in this filter. Are you going to be selling them and could i get a price for the the one that is replacement for the tymar?
Thanks
rydindirty is offline
