9008 (H13) and 9145 (H10) Ultimate Headlight Heavy Duty Wiring Harness! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dfuser, this thread has received 23 replies and been viewed 3524 times.
post #1 of 24 (permalink) Old 06-16-2006, 02:51 PM Thread Starter
Midway on the page
Easy to install, this wiring harness will supply battery voltage or more to your headlights.
This extra voltage will give you brighter, whiter headlights.
Simple plug and play installation using factory style (9008 Headlights and 9145 Foglights) connectors.
These are equipped with four (4) heavy duty 30 AMP relays and a fusible link for safety!
Will NOT work with Daytime Running Lights!
Includes two (2) special harness each powering one side of your vehicle (Driver and Passanger side) Headlights and foglights
Choose to have your Foglights stay on with the High or Low Beam (Factory fog light switch will be disabled with this harness)
PS: Also available for the 9007 and 9004 with and w/o factory foglights.
dfuser is offline
post #2 of 24 (permalink) Old 06-16-2006, 04:56 PM
I got one of these harnesses from Dfuser and can attest to the quality of the harness.
For those of you with the sensor on your dash that automatically turns on your heads or shuts them off depending on the ambient light....this harness WILL work and requires NO modifications....so don't confuse daytime running lights with this feature. Your lights will still come on and off with the sensor on your dash.
Bear Hunter is offline
post #3 of 24 (permalink) Old 06-17-2006, 04:09 AM
LokiWolf's Avatar
Is there a discount for us TDG memebers. If so PM me a price...
Thanks,
Loki
2006 F250 CC SB 4x4
4.5 Icon 4-Link, TEI Spacers, and 5 Inch rear Springs.
Farmboy Fabrication Traction Bars.
SCT XCalII tuned by GoGoDiesel, DJ's, and Spartan...
LokiWolf is offline
post #4 of 24 (permalink) Old 06-17-2006, 04:33 AM
me too
TXHNTR is offline
post #5 of 24 (permalink) Old 06-17-2006, 12:48 PM Thread Starter
:Thumbup: TDG memebers always get a special treatment!
dfuser is offline
post #6 of 24 (permalink) Old 08-31-2006, 02:12 AM
TDG Mafia Member #24
Can you make the harness so that the low beams and the highs stay on together?
:grd
"Can You Keep Up?"
AUGSX is offline
post #7 of 24 (permalink) Old 08-31-2006, 04:34 PM Thread Starter
Yes, but there is a problem with the 05+ headlight housing materials and the plugs them selves. They cannot handle the extra heat generated from both elements and extra voltage provided at the same time.
Typically at around the 15 minutes mark parts will start metling, when both engaged. Unlike the previous headlight and plugs, they can with stand the extra heat.
Now if we just allow the low beam to come in with the high beam w/o the harness that seem to work fine.
Bill
dfuser is offline
post #8 of 24 (permalink) Old 09-01-2006, 05:21 AM
Pm Me Too !!!
2005' F250 RED CC SB 4X4 AUTO 3.73
DEI auto start with auto timer
Bilstein leveling kit with shocks
Undercover bed cover
Dualcomp bed liner
http://smileys.smileycentral.com/cat/10/10_1_132.gif
pass gas is offline
post #9 of 24 (permalink) Old 09-03-2006, 04:34 PM
Does any of your kits, just run the headlight wile leaving the foglights to work with the oem switch. thanks
2006 F250 CC FX4, 4" MBRP turbo back. got rid of my POS 2003
wbigcount is offline
post #10 of 24 (permalink) Old 09-03-2006, 06:44 PM
Bill thanks for the reply, my reason for the question is because I am running HID's and a pair of KC's as high beams so I don't have the melting headlamp issue.
Thanks,
Augie
BTW PM me with the price of the harness no fog light option but I need it to run the low beams with the highs.
:grd
"Can You Keep Up?"
AUGSX is offline
