4 inch stainless for f350 6.0 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BogginF350, this thread has received 2 replies and been viewed 644 times.
post #1 of 3 (permalink) Old 06-25-2006, 05:00 AM Thread Starter
BogginF350's Avatar
Looking for a good price on a 4 inch with a 5 inch tip stainless setup on a 06` f350 crew long. No kitty. D2hp? Prefer magnaflow.
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #2 of 3 (permalink) Old 06-26-2006, 04:48 PM
Supporting Vendor
Boggin, sent you a PM
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #3 of 3 (permalink) Old 06-29-2006, 02:20 PM
BogginF350,
We can help you on MBRP and AFE exhaust, they also have a provision to "bolt" the cat in and out that Maganflow doesn't have that might be valuable to you as well.
Mark @ DPPI
Mark_Craig is offline
