OBS IC install kit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by POWER STROKE 99, this thread has received 3 replies and been viewed 886 times.
post #1 of 4 (permalink) Old 08-31-2007, 10:01 AM Thread Starter
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
OBS IC install kit
I thought I seen this on a site but can not find it.
POWER STROKE 99 is offline
post #2 of 4 (permalink) Old 08-31-2007, 11:51 AM
tjl
tjl's Avatar
Geoff at GTS Motorsports has the kit. That's where I got mine. It's a very nice kit. Has every thing you'll need. gtspowerstroke is his screen name here.
Tim
'96 f350 cc dually, 5 speed w/ short throw shifter, stage 1 injectors, '03 sd intercooler, d66 turbo, DP Tuner F5 chip (stock, high idle, tow, econo, extreme) modified IDM, CCV mod, gutted EBPV
343 hp
670 tq
Dually Club #20
B.O.M.B. Squad #7
tjl is offline
post #3 of 4 (permalink) Old 08-31-2007, 08:56 PM
Supporting Vendor
The banks kit has everything including the intercooler if you don't have one already from a Superduty.
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #4 of 4 (permalink) Old 08-31-2007, 09:38 PM Thread Starter
Can you get it with the IC, if so PM with the price......:thanks:
