Flex fan now availabel for 1999-2003 7.3L PS - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dfuser, this thread has received 2 replies and been viewed 710 times.
post #1 of 3 (permalink) Old 09-26-2007, 09:20 PM Thread Starter
http://www.dfuser.com/catalog/ford-s...ex-fan-kit.php
6.0L and OBS 7.3L are in the works.
dfuser is offline
post #2 of 3 (permalink) Old 10-03-2007, 07:23 PM
Send a message via AIM to TowRig
How hard are these to install?
AJ
2000 F-250 PSD Extended Cab Short Bed
-AutoMeter Gauges;Pyro, Tranny, Boost, Rear Diff, Fuel Pres, Air Pres.
-MBRP Turbo back, muffler delete
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
Trail rig: 1990 Jeep Cherokee, 4.0 I6, NP231 w/ SYE, Clayton Off road Long arm Suspension with coil conversion in rear, Full width Dana 44 up front(ARB, Warn Hubs and US Alloys Chromoly Axle shafts), full width Dana 60 in rear with Spool. 4.88 Gears all around, 36 inch Interco Bias Irok's, and lots of trail damage. :
TowRig is offline
post #3 of 3 (permalink) Old 10-03-2007, 09:00 PM Thread Starter
Took me 30 minutes.
You have to do the following:
Remove the coolant overflow out of the way
Loosen the fan nut (Clock wise)
Remove the upper Radiator hose
Remove the fan and shroud
Remove Water pump pulley bolts (4)
Remove belt
Install new fan and shroud (Tighten bolts)
Install Over flow bottle, belt, upper radiator hose
Refill fluid lost
and go
dfuser is offline
