Towing Chip - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_cummins_power, this thread has received 4 replies and been viewed 511 times.
post #1 of 5 (permalink) Old 12-28-2007, 06:15 AM Thread Starter
Towing Chip
1998 Dodge 24 valve Cummins 5 speed 4x4 dually extended cab stocker
Going to convert to a service rig for the farm. It will be hauling fuel, tools, air compressor, and a welder. It will also pull some smaller implements to aid in the transport process. Air compressor, maybe 500-750lbs. Welder close to the same. About 500 gal of diesel x 8 lbs/gal is 4000lbs. Plus a whole bunch of tools. Towing anywhere from 1000-10000 lbs. Doesnt need to be a hot rod, but some more torque would be nice for idleing around the fields. Exhaust upgrades will be added soon. Thanks
post #2 of 5 (permalink) Old 12-28-2007, 05:09 PM
KT Performance's Avatar
Logan, are you looking for something that is shift on the fly? If it is going to stay in the same tune for long periods of time, a programmer will be cheaper.
You will also need gauges, do you want something that comes with built in gauges or are you planing on adding analog gauges?
I just want to make sure you get the best option for your application.
Thanks,
Kenny
KT Performance is offline
post #3 of 5 (permalink) Old 12-29-2007, 12:51 AM Thread Starter
Well, I would be fine with just a programmer, but my dad thinks that when there is less load the horses should be turned down for economy purposes. I thought that if you upgraded and kept your foot out of it, then you wouldnt lose any mileage? And we have a pyro to put on ourselves. Shouldnt need boost with the stock turbo. If I can get some prices, then well see about the programmer vs shift on the fly.
post #4 of 5 (permalink) Old 12-29-2007, 03:28 AM
Pm sent
dfuser is offline
post #5 of 5 (permalink) Old 01-03-2008, 02:58 PM
ToddPSD's Avatar
FYI diesel weights 7.01 ppg and water weights 8.334 ppg. :sofa
1993 HMC4 Hummer 100% Grade A Beef
4bt Cummins and a couple of other things.
2008 F350 CCLB 4x4 6.4L
Naked.....
ToddPSD is offline
