DR 2.5" leveling kit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by NCR, this thread has received 3 replies and been viewed 423 times.
post #1 of 4 (permalink) Old 01-03-2008, 02:55 AM Thread Starter
NCR
Need a quote for the DR kit for truck in sig. Thanks
Rick
'06 F350 6.0 Lariat CC DRW 4x4 TOW BOSS 4:30's
zoodad, ccv re-route, accufab elbow, Isspro gauges, 4" Hog DP & 4" straight piped, sct, ARP headstuds, EGR delete pipe, Cass 190 inj, DJ's fuel+
NCR is offline
post #2 of 4 (permalink) Old 01-03-2008, 03:18 AM
Supporting Vendor
We have been having a hard time getting shocks. I will check and see what i can do.
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #3 of 4 (permalink) Old 01-03-2008, 03:30 AM Thread Starter
NCR
I'm open to other kits such as Bilstein or.....A kit that changes out the springs.
Rick
NCR is offline
post #4 of 4 (permalink) Old 01-13-2008, 06:01 PM
Good luck with the DR stuff, do some searching and you will find they are going out of buisness, but the guys that work there are trying to start a new company with the same products.
07 3500 5.9 QC LB AT 4x4 Edge Additude w/hot unlock S&B intake 5" Magnaflow exhaust
Trucks Sold
93 F250 7.3 Turbo SC LB 5 Speed 4x4 XLT Stock
2006 F350 6.0 CC LB AT 4x4 King Ranch SCT etc
2003 F350 7.3 SC LB AT 4x4 XLT H2E and more
1993 F250 7.3 LB IDI 2wd 5 speed XL Pump turned up
ontherks is offline
