leveling kit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jarods gerbils, this thread has received 4 replies and been viewed 627 times.
post #1 of 5 (permalink) Old 01-22-2008, 04:29 AM Thread Starter
member
Jarods gerbils's Avatar
leveling kit
looking for a inexpensive leveling kit. Nothing fancy and no more then 2". Need some ideas?
2006 F-350 6.0 crew cab long bed with line x.
2" leveling in front with 315/65/18 BFG's.
Billet grill
MBRP 4" duals, AFE stage 1, Tunes from Eric @ Innovative and DJ's.
Overhead pod with Isspro guages
Jarods gerbils is offline
post #2 of 5 (permalink) Old 01-22-2008, 04:24 PM
GOS
GOS's Avatar
Leveling Kit
PM is on the way.
Contact 1-800-620-4467
Fax 1-406-222-4926
[email protected]
GOS is offline
post #3 of 5 (permalink) Old 01-29-2008, 05:15 PM
ebay Item number: 120216574916
this is where I got mine, if you need pointers for install let me know
2005 F-350 Lariat Crew Cab Short Box 4x4 SRW
6.0L Torqshift, True Blue w/silver lower accent
FX4 pkg., 18" wheels, Luxury pkg., Tow Command
Upfitter switches, Heated seats
Airaid filter, MBRP 4" Turbo Back w'gutted cat & no muff.
Isspro Boost & Pyro Gauge
Propod Wedgee Dual Pod
SCT Xcal2 from Innovative Diesel w/extreme street
DJ's looney tune, 2" leveling kit
Procomp 1079 17x9 4.75 backspacing with 35x12.5 extreme mt's
powerstrokeit is offline
post #4 of 5 (permalink) Old 02-02-2008, 08:25 AM Thread Starter
member
Was it an easy install? How was it getting everything to line back up? Did you get tall shocks, did you have to get realligned afterward?
Billet grill
post #5 of 5 (permalink) Old 02-10-2008, 10:20 PM
real easy to install
remove front tires
disconnect swaybar end links both sides
disconnect shocks both sides
jack up till you can pull out springs
remove lower spring perch
put in spacer under perch
re-connect the above
I did not do an alignment yet, but it does need it
2" spacer will fit 35's with a 4.75" backspacing
