NEW!!!! AEM water meth kit! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by [email protected], this thread has received 1 replies and been viewed 748 times.
post #1 of 2 (permalink) Old 04-24-2008, 04:53 PM Thread Starter
http://www.xtremediesel.com/index.as...OD&ProdID=2192
REDUCE INLET AIR TEMPS & EGTs TO
RUN MORE BOOST!
WHY USE AEM's WATER/METHANOL INJECTION KIT?
The new HD Water/Methanol Injection Kit is specifically designed for turbo-diesel and gas applications and includes multiple jets to suite your car or truck's power needs. The kit reduces air inlet temperatures and EGTs, which allows you to increase boost pressure and advance timing... leading to more power and safer operating conditions!
NO HIDDEN COSTS... EVERYTHING IS INCLUDED! The HD Water/Methanol Injection Kit includes all the features necessary to do water/meth injection right. No hidden costs or optional components are required. Unlike other popular kits on the market, AEM includes a five-gallon tank with a fluid level sensor standard. Another standard feature is the boost-dependent, variable-flow progressive controller, which determines the amount of water/methanol mixture (up to 50%) to feed into the inlet stream. Flow adjustments at the inlet are made via three supplied jets that are designed to match most engine power requirements.
BOOST SAFE ENSURES ENGINE PROTECTION. Also, because AEM's engineers believe engine protection is a requirement, not an option, we include our Boost Safe output in every controller we design. This feature allows you to retard timing or reduce boost if the system runs out of fluid or detects an error. With an AEM HD Water/Methanol Injection Kit, you get all the best features in one low-priced kit.
FIVE-GALLON TANK DIMENSIONS AND MORE INFO. The new five-gallon tank that is included in the HD Water/Methanol Injection Kit measures approximately 21-inches in length, 8-inches in width, and 10-inches in height. The tank is constructed of high-density polyethylene, which is very resistant to chemicals and moisture, making the material ideal for your water/methanol mixture. In addition, mounting the reservoir will be safe and secure with reinforced 1-inch mounting tabs that are located at each corner.
KEY FEATURES Kit includes everything needed for installation
  • Large-capacity 5-gallon reservoir with integral fluid level sensor
  • Boost Safe lets you retard the timing or reduce boost if the system runs out of fluid or detects an error
  • Progressive, controller-driven 150-PSI pump provides boost-dependent variable flow
  • Dash light relays system status and low fluid warning
  • Methanol & alcohol compatible (up to 50% in solution with water)
  • Includes three jets to match your power requirements
  • Reduces exhaust gas temperatures (EGTs) and inlet air temps on turbo-diesel and gas applications
post #2 of 2 (permalink) Old 04-24-2008, 06:01 PM
damn, i didnt know AEM came out with a water meth kit...
2003 Ford F350 FX4 6.0L - 2007 Front Clip
16" Custom Lift/Dual Reservoir shocks/Traction Bars
42x15R20 Swamper SX2's/20x12 black XD Rockstars
Road Armor Stealth front-rear Bumpers/AMP Powersteps
Recon Smoked LED everything/Smoked LED 1 pc Headlights
SCT Xcal3 Tuned by DJ/Josh's 190cc injectors/DJ's Fuel Intensifier
ARP headstuds/Dfuser EGR delete/7" black stack
94 2500 12v - Reg cab 4x4
Wicked Diesel S300-S400 twins/Airdog Fuel pump
DDP fireringed head/DDP injectors/ARP headstuds
ATS manifold/MBRP exhaust/AFE filter
Garmon "whoop azz" trans, and lots more
WHITEPOWERstrok is offline
