AMSOIL Diesel Air Intake Systems by Injen - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CrowsSynthetics, this thread has received 0 replies and been viewed 553 times.
post #1 of 1 (permalink) Old 05-04-2008, 05:44 PM Thread Starter
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
Post AMSOIL Diesel Air Intake Systems by Injen
Amsoil Introduces an Air intake system that Delivers!
Increased Oxygen Means
Increased Power
Injen/AMSOIL Diesel Air Intake Systems increase the
amount of oxygen available to the engine, increasing
power. Because cool air has a greater density than hot
air, Injen/AMSOIL Diesel Air Intake Systems improve
combustion of the fuel by capturing cooler air from the
outside of the engine compartment. Injen/AMSOIL Diesel
Air Intake Systems can also improve gas mileage and
increase performance.
Quality Construction
The Injen/AMSOIL Power-Flow Diesel Intake Series
incorporates revolutionary Variable Induction Technology.
The new Vi Technology process is a multi-power air
induction system that fills the plenum with air giving
added power on demand.
The Power Box was designed for advanced cooling
efficiency and the ability to resist high temperatures.
The Power Box will not distort, unlike other plastic components
that may lose their structural integrity over time.
Injen/AMSOIL Diesel Air Intake Systems are manufactured
with aerospace alloy T6 aluminum, stainless
steel clamps and tig-welded ports and brackets. They
are dyno-tuned for peak performance and have a direct
bolt-in application, making installation quick and easy.
AMSOIL Ea Air Filters
Adding to the high quality of the intake system are
AMSOIL Ea Air Filters. AMSOIL Ea Air Filters are made
with super high-quality synthetic nanofibers. AMSOIL
designed, developed and manufactured special EaA
Diesel Intake Filters for the system. AMSOIL Ea Air
Injen/AMSOIL Diesel
Air Intake Systems
Filters provide superior protection and maximum efficiency
for engines by filtering more harmful contaminants
while maintaining proper flow.
Cleanable
AMSOIL Ea Air Filters are cleanable, offering longer filter
life. AMSOIL recommends cleaning the Ea Air Filter
when designated by the restriction gauge if the vehicle
is so equipped, or according to operating conditions.
They are cleaned by using either low-pressure shop air
on the clean side or a vacuum on the dirty side.
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
