New AMSOIL Premium API CJ-4 Synthetic 5W-40 & 15W-40 Diesel Oils - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CrowsSynthetics, this thread has received 4 replies and been viewed 1090 times.
post #1 of 5 (permalink) Old 03-17-2009, 06:12 PM Thread Starter
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
AMSOIL upgraded the technology on DEO, increased the TBN to 10.4 and created a compelling extended oil drain capability of up to three times (3X) original equipment manufacturer’s (OEM) recommendations. The extended drain interval on the reformulated DEO is now defined using both miles and hours for a wide variety of on‐road and off‐road applications. Upgraded AMSOIL Premium API CJ‐4 Synthetic 5W‐40 Diesel Oil also has a documented fuel efficiency benefit of up to 3% over conventional 15W‐40 diesel oils. With the upgraded technology, AMSOIL DEO can also be recommended for a longer list of worldwide specifications.
How did we do this?
Answer: AME is an outstanding product for wear protection and was the standard used to build the new Premium API CJ‐4 Synthetic 15W‐40 Diesel Oil (DME). AMSOIL Premium 15W‐40 Diesel Oil is formulated to resist breakdown from continuous operation and high loads. Built with heavy duty detergent/dispersant additives, this high TBN (10.4) formula is naturally resistant to the detrimental effects of high soot loading. It keeps soot particles suspended independently, preventing them from attaching together to form larger, wear causing particles. AMSOIL Premium 15W‐40 resists heat and breakdown better than conventional petroleum oils for long lasting performance and protection.
So how does this affect the new diesels.
Answer: You can go ‘3X OEM’ refers to the extended drain interval definition of AMSOIL 5W‐40/15W‐40 diesel oils. ‘3X OEM’ means AMSOIL diesel oils extend drain intervals up to three times (3X) the original equipment manufacturer’s (OEM) recommendation as stated in the owner’s manual or other supporting technical documents. For example, the OEM drain interval recommendation is 15,000 miles for a Volvo with an ISX engine under severe service, thus AMSOIL CJ‐4 Diesel Oils will extend the drain interval to 45,000 miles. Likewise, a Kubota M8200 Series Tractor has an OEM drain interval recommendation of 200 hours; AMSOIL CJ‐4 diesel oils extend this drain interval to 600 hours.
AMSOIL drain interval cap ‘Not to exceed 50,000 miles/600 hours or one year, whichever comes first’
Call an ask for much more info on this new product.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #2 of 5 (permalink) Old 03-18-2009, 02:22 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
of course this comes out after I put 10w-30 in my truck... I guess there is always next year...
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 5 (permalink) Old 03-18-2009, 03:21 PM Thread Starter
I have 8 gallons in stock what oil has 10 w30?
5" SS Tip
post #4 of 5 (permalink) Old 03-18-2009, 04:17 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
I just filled my truck up w/ this
post #5 of 5 (permalink) Old 03-18-2009, 06:28 PM Thread Starter
Let me know how it works for you? I really never considered that oil I was under the impression it was for heavy equipment. That has high pressure injectors like the JD & Cat.
Bill
5" SS Tip
synthetic gear oils indyfitter05 Duramax 2004.5-2005(LLY) 19 03-02-2009 01:43 AM
AMSOIL Motor Oils, Flat Tappet and Camshaft Lobe Lubrication CrowsSynthetics General Diesel 7 01-01-2009 02:49 AM
Synthetic and paraffin based Motor oils seapig 2008-2010 6.4L Power Stroke 5 01-13-2008 06:29 PM
synthetic for Diesel VS synthetic that can be used in diesels jethrow General Ford Truck and Excursion 8 12-08-2007 07:35 PM
Rotella/Amsoil Synthetic? HTRDDSL 2008-2010 6.4L Power Stroke 3 07-26-2007 01:13 AM
