AMSOIL Introduces Extended Life Synthetic 15W-40 Diesel Oil for CJ-4 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CrowsSynthetics, this thread has received 1 replies and been viewed 831 times.
post #1 of 2 (permalink) Old 03-31-2009, 02:17 AM Thread Starter
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
This is from www.truckinginfo.com
3/24/2009
AMSOIL has introduced a new Premium API CJ-4 Synthetic 15W-40 diesel oil. The new oil is an upgrade to the company's most popular 15W-40 viscosity, now re-formulated for the 2007 CJ-4 specifications without sacrificing its extended service life. The new emission-compliant oil is backward compatible, thus offering maximum protection in all diesel applications including those with exhaust treatment devices.
AMSOIL Premium API CJ-4 Synthetic 15W-40 is formulated using the latest, high-quality synthetic base oils and most advanced additive chemicals. Its heavy-duty detergent/dispersant additives and high 10.4 TBN control soot thickening from exhaust gas recirculation (EGR) and blow-by to protect against corrosion, cylinder bore polishing (wear) and varnish/sludge deposits. AMSOIL Premium diesel oil is shear stable and provides exceptional oxidation stability to resist heat and breakdown from continuous operation and high load. In addition, the low sulfated ash formulation promotes long diesel particulate filter (DPF) life.
AMSOIL 15W-40 is engineered for a wide range of applications, allowing fleet operators to consolidate engine oil inventories in mixed fleets. By reducing downtime through both extended drain intervals and improved equipment protection, AMSOIL Synthetic 15W-40 provides real savings for fleets and owner/operators. Due to its high TBN content, AMSOIL Synthetic 15W-40 Premium diesel oil is recommended for extended service life in engines that are unmodified and in good operating condition. The recommended drain intervals is three times OEM recommendations, not to exceed 50,000 miles/600 hours or one year, whichever comes first. Drain intervals may be extended further with oil analysis.
AMSOIL Premium API CJ-4 Synthetic 15W-40 is recommended for diesel engines and, where appropriate, certain gasoline engines. For more information contact www.amsoil.com.
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #2 of 2 (permalink) Old 04-03-2009, 02:07 AM Thread Starter
A little more Info
Here is PDF's on two new oils for API CJ-4 emission-quality diesel oil required by model-year 2007 and newer diesel engines.
Bill
File Type: pdf API CJ-4 Synthetic 15W-40 Diesel Oil (DME).pdf (143.1 KB, 41 views)
File Type: pdf API CJ-4 Synthetic 5W-40 Diesel Oil (DEO).pdf (143.8 KB, 44 views)
5" SS Tip
Tags
amsoil diesel cj4
New AMSOIL Premium API CJ-4 Synthetic 5W-40 & 15W-40 Diesel Oils CrowsSynthetics Supporting Vendors Forum 4 03-18-2009 06:28 PM
NAPA Extended Life Coolant? NCfarmboy 2003-2007 6.0L Power Stroke 2 01-19-2008 12:56 PM
synthetic for Diesel VS synthetic that can be used in diesels jethrow General Ford Truck and Excursion 8 12-08-2007 07:35 PM
Rotella/Amsoil Synthetic? HTRDDSL 2008-2010 6.4L Power Stroke 3 07-26-2007 01:13 AM
year round synthetic oil for a 6.0 diesel? yamaman General Ford Truck and Excursion 10 02-19-2006 10:12 AM
