Making a Drive Pressure setup - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins power, this thread has received 4 replies and been viewed 799 times.
post #1 of 5 (permalink) Old 04-06-2009, 11:49 PM Thread Starter
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Need an Autometer Z Series 0-60 psi gauge. Send me info with the price and everything that comes with the gauge. I'd like to have it here by Thursday. Lowest bidder gets it. Thanks, Logan
Logan
Do Or Die Garage Experiment
cummins power is offline
post #2 of 5 (permalink) Old 04-07-2009, 01:09 AM
CSIPSD's Avatar
I would get a 100psi gauge, what turbo are you running? You will need about 12" or so of copper 1/8" tubing to go from the exhaust manifold to the plastic 1/8" line to the gauge. Make a loop (or 3-4 of them) around a piece of 1.5" tubing (or similar)... Then a union.
CSIPSD is offline
post #3 of 5 (permalink) Old 07-21-2009, 06:54 PM
what is drive pressure for
boostenhard is offline
post #4 of 5 (permalink) Old 07-21-2009, 08:57 PM
It is the exhaust pressure to drive the turbo, use this to compare to boost.
2003 6.0 6sp Black, black 6in stacks, scan gauge, gauges, Fass 150/180, ARP headstuds, RCD 200cc injectors SBC 3600 DD 12 cb, SCT X2, AFE stage 2 intake, zoodad mod, custom traction bars, a 2.6 66mm turbo in the making, and more fabricated parts in the near future. a 2.6 class 6.0 puller
Work truck: chevy 3500 454ci hightop fully enclosed reading utility bed
Gavin
03strokerGavin is offline
post #5 of 5 (permalink) Old 07-21-2009, 11:02 PM
ya man i looked it up thanks anyway
Pics of Drive Pressure gauge install. midnight2004 2003-2007 6.0L Power Stroke 11 03-19-2009 07:35 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-10-2009 12:35 AM
Making a 45* cut. 2tonePSD 1994-2003 7.3L Power Stroke 14 03-18-2008 10:30 PM
Making a 2wd a 4wd CAMperformance 5.9L Cummins (Pre 1994) 1 03-28-2007 04:46 AM
Drive like Granny=OK, Drive like Earnhardt=stalls at idle GeneralLeo 1994-2003 7.3L Power Stroke 3 09-15-2006 04:39 AM
