6.0 crossover fuel lines. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by the blue beast, this thread has received 2 replies and been viewed 755 times.
post #1 of 3 (permalink) Old 04-07-2009, 04:18 AM Thread Starter
the blue beast's Avatar
Putting the engine in this weekend and while it is out i would like to put them on. Don't have the money for a regulated return, but would like to do the cross over. Thanks in advance
Darren
Darren
04 ex cab Long Bed 6spd blue, pocket fender flares, rollpan, smoked tail lights, harley head lights, recon smoked third brake light, and 16/10 classics
6.1 built by Me, with parts from Josh at rcd, bulls eye 66/74/12cm s300, 44mm tial wastegate, speraco intercooler, hellman sump with 5/8 hose feeding the fass to 1/2 to a y block the 3/8 to the heads, outhbend 3600 double disc
Tuned by sct of course...
custom trac bars, and weight bracket with 800#
singles club #36
the blue beast is offline
post #2 of 3 (permalink) Old 04-07-2009, 09:18 PM
bootcamp's Avatar
Darren did you check the Ford parts list, I thought some body in there had one for sale at one time. May be already sold. But might be worth the search.
Paul
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
The Following User Says Thank You to bootcamp For this addition to TDG:
the blue beast (04-08-2009)
post #3 of 3 (permalink) Old 04-08-2009, 11:29 PM Thread Starter
No i didn't paul i will have to check thanks for the info.
Darren
singles club #36
Fuel crossover line 04' powerstrokin 2003-2007 6.0L Power Stroke 21 01-01-2009 09:37 PM
I have foresale a Dj fuel intisier kit with braided lines. All lines and fittings tha Robts Whats Been Sold 3 05-02-2008 12:10 AM
Fuel crossover line One Fast Harley 2003-2007 6.0L Power Stroke 3 01-24-2007 05:00 AM
fuel x-crossover test imported_diesel71 2003-2007 6.0L Power Stroke 22 07-27-2006 03:35 AM
Fuel Crossover Mod imported_BigGreen 1994-2003 7.3L Power Stroke 19 04-30-2006 07:07 AM
