will a wicked wheel work on a early 99 250 stroke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by two05gixxer, this thread has received 30 replies and been viewed 3273 times.
post #1 of 31 (permalink) Old 12-29-2005, 01:48 AM Thread Starter
I have a 1999 f250 power stroke and was wanting that turbo to scream, my friend has an 03 with mbrp ex. and his is great it sounds like a plane. Well i bought the same system excpt. mine is from the turbo all the way back and it didnt really make a huge diff. in the sound quality so i was wondering what i could do to make it whistle a little louder without dropping a huge chunk of change. Also how do i tell if my truck is the early or late model 99 and what is the diff. between the two thank you guys very much:thanks:
two05gixxer is offline
post #2 of 31 (permalink) Old 12-29-2005, 02:01 AM
4cstr
Look on the door and see when the build date was. If it says anything in 98 then you have an early 99...much like mine. IF after 12/98 you have a late 99 model.
The early 99 turbine wheel is basically the wicked wheel. If you have an early 99, open up the intake with something that allows better breathing. You have already opened up the exhaust.
Mine whistles very nicely
post #3 of 31 (permalink) Old 12-29-2005, 02:04 AM
RSP
Rockin-S
Ok The early 99 trucks have the V8 Powerstroke Badges on the front of the front fender, 99.5 and later have the Power Stroke badges on the doors. Also the Turbo is much smaller on an early 99. If you have an early 99 then you already have a wicked wheel, Just a smaller Turbo.
97 F350 PSD Crew Cab 4X4 Almost Stock :umno:
79 F250 CTD Super Cab 4X4 Almost Stock
79 F150 Reg Cab 4X4 Whimpy 512 CI BigBlock Some day it will be a CTD too
RSP is offline
post #4 of 31 (permalink) Old 12-29-2005, 02:05 AM Thread Starter
thanks for the input i dont really care about the torque or power i just want it to sound nice i was thinking about fabricating an intake system myself
post #5 of 31 (permalink) Old 12-29-2005, 02:05 AM
4cstr
You can't really go by the fender badges. They started going to the door badges before the went to the bigger turbos...so there are a few early 99's with door badges.
post #6 of 31 (permalink) Old 12-29-2005, 02:07 AM Thread Starter
so mine says V8 powerstroke on the side so i have an early 99?? so no need for the ww huh? what else would you suggest for the noise i hate that i spent 400 bucks on the exhaust and its sounded just like my old 03 with a straight pipe , 1 more question why doesnt my truck pump that black smoke out when i get on it?
post #7 of 31 (permalink) Old 12-29-2005, 02:09 AM Thread Starter
or are you talking about the fender as opposed to the door?
post #8 of 31 (permalink) Old 12-29-2005, 02:11 AM
if its on the front fender you should have an early 99 if its on the door it shoudl be late 99 and up
DBogo is offline
post #9 of 31 (permalink) Old 12-29-2005, 02:12 AM Thread Starter
ok my v8 powerstroke badge is on the driver and passenger side door not the fender so do you suggest i get the wicked wheel and will i notice a good amount of noise once the install is complete. and how hard is it to do the install?
post #10 of 31 (permalink) Old 12-29-2005, 02:18 AM
RSP
Rockin-S
Ok Well I Stand corrected, I just Never Ever seen an early 99 with Door badges.
RSP is offline
