Now available Injectors Powerstroke 7.3/6.0L - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dfuser, this thread has received 6 replies and been viewed 736 times.
post #1 of 7 (permalink) Old 05-08-2009, 06:19 AM Thread Starter
http://www.dfuser.com/catalog/powerstroke-injectors.php
Thank You
dfuser is offline
post #2 of 7 (permalink) Old 05-08-2009, 06:48 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
mmmmmmmm.......gots me thinking...
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #3 of 7 (permalink) Old 05-08-2009, 07:38 AM
7.3 addict
what kind of h/p increases do you see with each step in size (just ball park)
1) 99 f-350 srw 7.3 6pos. bully dog, afe intake, mrbp 4" exhaust,250,000 miles and still rollin.
2) 2000 excursion 7.3 afe intake, mrbp 4" exhaust. chip coming
3) NEW TO ME2000 cc drw 7.3 let the mods begin
4) FOR SALE 87 f250 6.9 9' utility body.
5) SOLD 91 f150 good truck just well used.Gonna miss the old girl allways started even after sitting for 6 months.
I think i'm trailer poor ) 22' w\18' tilt car hauler, 18' flat bed, 2 horse D&D, 12' utility, 19' "v" nose, and 37' 5er
"quote from tank"
"I use baby wipes.....
Because if you think that a wadded up piece of paper is actually getting the chit off of your butt.....then I have to ask a question....
.....if you wiped a turd on your arm....would you just use a paper towel to get the turd off?.....or would you wash your arm?...
...let that thought roll around in your head for a moment...
" thank you tank for that insightful thought
#46 AMERICAN (blood) club
#241 singles club
# ? Dually club
# ? Excursion club
jestersv is offline
post #4 of 7 (permalink) Old 05-08-2009, 10:45 AM
UpstateDieselGuy's Avatar
Nice addition. Chris
SOLD
UpstateDieselGuy is offline
post #5 of 7 (permalink) Old 05-08-2009, 01:38 PM Thread Starter
HP gains are mostly tied to what your turbo and HPOP can put out as well as tunning. typically about 25+ jump in HP.
dfuser is offline
post #6 of 7 (permalink) Old 05-09-2009, 01:13 AM
TANK'S 250's Avatar
Images: 38
HPOP is no longer a factor,...especially now that Shawn Ellerton put down 1004rwhp on a stock 05 HPOP
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #7 of 7 (permalink) Old 05-09-2009, 03:38 AM Thread Starter
COrrect on the 6.0L. The 7.3L is still HPOP challanged!
dfuser is offline
Performance Injectors Or Stock Injectors imported_Stroker01 1994-2003 7.3L Power Stroke 8 05-06-2008 05:16 PM
6.0 powerstroke injectors Sabbath5.9 Whats Been Sold 7 11-24-2007 01:06 AM
7.3 Powerstroke DIY-Injectors jmorton Ford - Modification instructions, Product installs and Tech Articles 0 02-12-2007 11:42 PM
OBS Powerstroke Swap to SD Powerstroke Question Dieselwrencher 1994-2003 7.3L Power Stroke 6 12-02-2006 02:30 AM
need 6.0l powerstroke injectors rebornstroke Whats Been Sold 0 09-27-2006 11:58 PM
