RCD 6.0 Ford Leakproof Egr Delete. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BogginF350, this thread has received 16 replies and been viewed 13440 times.
post #1 of 17 (permalink) Old 05-12-2009, 03:31 AM Thread Starter
BogginF350's Avatar
After dealing with some shady EGR deletes I took it upon myself to build the EGR delete that would put the others to shame. What makes the River City Diesel EGR Delete the BEST?
10 good reasons..
1. O-ring boss seals.
(no silicone, no mess, easy removal)
2. CNC machined from Billet T6 aluminum.
(not steel)
3. Uses factory hardware (threaded parts)
(no loose nuts, no trying to get them started and tighten them under the intake. I'm no Houdini and I'm sure you are not either..)
4. No "tabs" holding a fabricated tube in place.
(what keeps that thing from bouncing with every bump and wearing out the o_rings and intake bore? Ohh wait.. Nothing)
5. 304 Stainless steel mandrel bent up-pipe.
(Ford uses 409 grade and it can`t take the heat. Literally..)
6. The best TIG welds in the business.
7. Mandrel bent 304 thick wall loop tube.
8. Proven compression fitting seal.
(Rated Over 250 Psi, bring it on head gaskets.. I dare ya..)
9. Proudly built here in Peoria, IL ..
10. And like always, Free Shipping in the lower 48
$549
Name:	Egr delete 1.jpg
ID:	18839   Click image for larger version
Name:	egr delete 2.jpg
ID:	18840   Click image for larger version
Name:	egr delete 3.jpg
ID:	18841   Click image for larger version
Name:	egr delete 4.jpg
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #2 of 17 (permalink) Old 05-12-2009, 11:02 AM
UpstateDieselGuy's Avatar
Very nice kit!
SOLD
UpstateDieselGuy is offline
post #3 of 17 (permalink) Old 05-12-2009, 12:23 PM
singles member #53
s_bogedain's Avatar
2003 ford f-350 crew cab short bed 4x4 sct, billet grille, clear corners, recon cab and mirror lights, silverstar head and fog lights, bed liner, tonneau cover, tinted windows, double din touch screen dvd player, bully dog RFI intake, no egr, 5" exhaust, 2 10 inch clarion subs, EDGE for monitoring, window vents,
1997 dodge dakota ext short box all i can say is....440 and spray.
1998 ford escort. everyday beater
s_bogedain is offline
post #4 of 17 (permalink) Old 05-12-2009, 01:36 PM
Haulin' Hay
NCfarmboy's Avatar
Nice looking kit!!
NCfarmboy is offline
post #5 of 17 (permalink) Old 05-12-2009, 02:08 PM
strokin6L's Avatar
extremely very nice kit josh. You da man!
strokin6L is offline
post #6 of 17 (permalink) Old 05-12-2009, 02:48 PM
bluovldeezl's Avatar
Looks good!
2006 F-250 ccsb 4x4
NOT STOCK!!
bluovldeezl is offline
post #7 of 17 (permalink) Old 05-12-2009, 02:50 PM
TDG Mafia Member#67
6L strokin's Avatar
WOW josh...was this a factory option?? beautiful kit man! def no hacks there !!!
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #8 of 17 (permalink) Old 05-12-2009, 03:28 PM
Administrator
fordt's Avatar
Images: 5
I got to say, that is one clean looking kit!
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #9 of 17 (permalink) Old 05-12-2009, 05:37 PM
I'm not sure who else is ordering one but I ordered it last night and I'll let everyone know how the install goes... Looks awesome!
'03 F250 CCSB SRW, SCT, K&N, MBRP STRAIGHT PIPED, SNOW STG 3, LIFTED 6" ON 37'S, RCD's EGR DELETE, AP HD200, TP STG 1 FUEL SYSTEM, HYPERMAX STG 1 INJECTORS, ARP'S, ID TUNED, VARIOUS LITTLE GOODIES...
R33615 is offline
post #10 of 17 (permalink) Old 05-12-2009, 09:12 PM
04lariatfx4crewcab's Avatar
Josh,
On your web site you have a egr delete kit for $599 but it comes with a modified intake and there is a $200 core charge that is refunded when old intake is returned to you. Is this the same kit?
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
6.0 Ford Egr Delete Up-pipe BogginF350 Supporting Vendors Forum 6 04-08-2009 10:42 PM
Ford Reflash and SCT w/ Delete. Fasteddie08 2008-2010 6.4L Engine Tuner Forum 9 02-05-2009 05:46 AM
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 10:45 PM
Ford Cat Delete Notorious6.0 2003-2007 6.0L Power Stroke 2 10-05-2005 10:10 PM
Fitting a Ford cat delete nummit 2003-2007 6.0L Power Stroke 0 08-05-2005 06:12 PM
