arp head studs - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 4 replies and been viewed 580 times.
post #1 of 5 (permalink) Old 05-26-2009, 02:56 PM Thread Starter
bootcamp's Avatar
arp head studs
Looking for a great price on a set of studs.
thanks Paul
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #2 of 5 (permalink) Old 05-26-2009, 08:58 PM
KT Performance's Avatar
PM on the way.
KT Performance is offline
post #3 of 5 (permalink) Old 05-27-2009, 01:20 AM
BogginF350's Avatar
http://www.rivercitydiesel.com/22141.html
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #4 of 5 (permalink) Old 05-27-2009, 08:18 PM
GOS
GOS's Avatar
PM coming.
Contact 1-800-620-4467
Fax 1-406-222-4926
[email protected]
GOS is offline
post #5 of 5 (permalink) Old 05-28-2009, 03:20 AM
pm sent
dfuser is offline
Need 6.0 Head studs G SQRD Supporting Vendors Forum 4 02-22-2009 01:08 AM
Hypermax Head Studs and Head Gasket HotSauce2138 Supporting Vendors Forum 11 04-28-2008 05:40 PM
Head studs ? TheNightmare 5.9L Cummins 12 Valve (1994-1998.5) 23 04-01-2008 03:11 AM
head studs 7.3 4x4 power Supporting Vendors Forum 2 02-08-2008 04:35 PM
Head studs blowin smoke 2003-2007 6.0L Power Stroke 12 01-19-2006 04:18 AM
